Ping spikes
- Ping spikes
Re: Ping spikes
01-07-2015 1:34 PM
Re: Ping spikes
01-07-2015 2:51 PM
Re: Ping spikes
01-07-2015 3:31 PM
Re: Ping spikes
01-07-2015 4:18 PM
Re: Ping spikes
01-07-2015 5:20 PM
http://s1361.photobucket.com/user/ronwillsher/media/WP_20150701_17_18_03_Pro_zpsm4e4xmrn.jpg.html
Re: Ping spikes
02-07-2015 11:41 AM
I've checked for capacity issues and there aren't any in your area.
Can you try and reset your router? There was a slight MTU issue in the past and I'm not sure if this could be a cause.
Re: Ping spikes
02-07-2015 12:15 PM
Now on ptw-ag04. and getting horrendous buffering on any catch up TV
Re: Ping spikes
02-07-2015 2:48 PM
Re: Ping spikes
02-07-2015 5:30 PM
Now on ptw-bng01. after reset
Re: Ping spikes
03-07-2015 11:24 AM
Re: Ping spikes
03-07-2015 2:09 PM
Re: Ping spikes
05-07-2015 7:32 AM
Re: Ping spikes
06-07-2015 3:02 AM
Personally I'd replace cables and think about swapping out the default ECI and Plusnet router combination and go for an AIO solution like a Billion or Zyxel, though that's the more pricey approach it could also be helpful to get a router that will show you stats like errors so you can check if they're bursting at certain times which would be the possible cause of any ping spikes
Re: Ping spikes
06-07-2015 6:09 AM
Re: Ping spikes
17-07-2015 5:29 PM
I still getting same
Now i got this TBB result
