Ping spikes
rongtw
Fixes: 12
Ping spikes
I have noticed just lately my gaming has had a few problems again  Sad
so i started checking with ping plotter , as i cant use my TBB  because i have a new Fast PN thompson and i notice that i get regular ping spikes continuously
rongtw
Fixes: 12
Re: Ping spikes
new Gateway still ping spikes regular intervals  Huh
sspen63
Re: Ping spikes
Same problems here.
rongtw
Fixes: 12
Re: Ping spikes
still here , yet another day
Re: Ping spikes
It looks to be on your network no?
rongtw
Fixes: 12
Re: Ping spikes
Andy H everything in my house is New  as had it all replaced by PN a few month ago because of a Packet loss problem caused by my old router .
BT replaced the Moden and PN replaced my router with the New Fast PN one Smiley
Re: Ping spikes
Was anything running when you were doing those tests though? Does the top right bar chart show min/max/avg latency for each hop?
The only reason I say it looks your end is that the max latency (if that is what the bar chart shows) seems to be high on your first hop.
rongtw
Fixes: 12
Re: Ping spikes
Hi Andy i see what you mean , but i was just surfing at the times Smiley
on first , highest was hop 4 117
next was hop 9 104
then hop 2 80
ok they may not be too high But its the recurring  frequency that causes problems for me
Re: Ping spikes
It's a strange one as the bottom bar chart looks to show some kind of similarities with the ping spikes.
It's ok to have high pings on certain hops as long as the destination hop is at a normal level (which I guess should be something like 10-15ms for bbc.co.uk for you).
rongtw
Fixes: 12
Re: Ping spikes
Andy sorry but the bottom bar chart is the PING spikes ,,,  Crazy
rongtw
Fixes: 12
Re: Ping spikes
another day another gateway and still getting spikes  Sad
Re: Ping spikes
The bottom bar chart is weird in that the pattern looks very similar - 5 ping spikes, first one highest then gradually reducing.
Can you try the pathping bbc.co.uk command from the cmd prompt?
rongtw
Fixes: 12
Re: Ping spikes
yup
rongtw
Fixes: 12
Re: Ping spikes
well i posted 4 days ago and still waiting for PN staff to give some input  Lips are sealed
Re: Ping spikes
What was the outcome from the pathping test?
