Ping spikes
- Re: Ping spikes
Ping spikes
22-10-2016 2:42 PM
Hi
I seem to be getting a lot of ping spikes. Im a gamer and as you can imagine its not very good when your pings jumping from 16ms to 140ms and everything in between. I was wondering could someone take a look at this please. Im on a wired connection and nothing has changed on my setup from this started happening....
Re: Ping spikes
22-10-2016 5:07 PM
Is there anybody out there......
Re: Ping spikes
23-10-2016 7:09 AM - edited 23-10-2016 7:11 AM
Its weekend CS staff are sparse
Are testing wired or WIFI ? what is your current speed , and are you using the PN supplied router
Re: Ping spikes
23-10-2016 10:16 AM - edited 23-10-2016 10:22 AM
hi
I didnt think there would be too many about at the weekend.....
Im using a wired connection for testing.
My speed is fine its just the ping jumping
And im using my own router..
Re: Ping spikes
23-10-2016 10:28 AM - edited 23-10-2016 10:31 AM
http://www.speedtest.net/result/5738145495.png
Nothing wrong with the speed......
Re: Ping spikes
23-10-2016 1:25 PM
It would help if you have a TBB graph http://www.thinkbroadband.com/ping
Create a new one by adding your IP
Re: Ping spikes
24-10-2016 10:50 AM
How long do the jumps in ping last? Is it to any game in particular or do you notice this outside of games too?
