Ping spikes
- Re: Ping spikes
Ping spikes
22-06-2015 10:26 AM
so i started checking with ping plotter , as i cant use my TBB because i have a new Fast PN thompson and i notice that i get regular ping spikes continuously
Re: Ping spikes
22-06-2015 1:14 PM
Re: Ping spikes
22-06-2015 1:26 PM
Re: Ping spikes
23-06-2015 9:50 AM
Re: Ping spikes
23-06-2015 9:57 AM
Re: Ping spikes
23-06-2015 4:04 PM
BT replaced the Moden and PN replaced my router with the New Fast PN one
Re: Ping spikes
23-06-2015 5:35 PM
The only reason I say it looks your end is that the max latency (if that is what the bar chart shows) seems to be high on your first hop.
Re: Ping spikes
23-06-2015 5:44 PM
on first , highest was hop 4 117
next was hop 9 104
then hop 2 80
ok they may not be too high But its the recurring frequency that causes problems for me
Re: Ping spikes
23-06-2015 5:50 PM
It's ok to have high pings on certain hops as long as the destination hop is at a normal level (which I guess should be something like 10-15ms for bbc.co.uk for you).
Re: Ping spikes
23-06-2015 10:26 PM
Re: Ping spikes
24-06-2015 10:00 AM
Re: Ping spikes
24-06-2015 10:15 AM
Can you try the pathping bbc.co.uk command from the cmd prompt?
Re: Ping spikes
24-06-2015 10:28 AM
Re: Ping spikes
25-06-2015 10:47 AM
Re: Ping spikes
25-06-2015 10:53 AM
