Ping creeping up in past 24 hrs
St3
Aspiring Champion
Fixes: 5
Hmm is interleaving on or off on my account ?
The first 2 weeks of fibre ive had a solid connection of around 72 meg down and 18 up with pings of 15ms which is just how i likes it Smiley
The past 24 hours my pings jumped to 38ms ive jumped gateway twice which sometimes fixes the high ping.
Can someone at plusnet take a peak at my connection and see if interleaving is on or off because im unsure what its set too.
Fixes: 187
Re: Ping creeping up in past 24 hrs
Hi there.
More then happy to look into this for you but I can't find your account for some reason.
If you can PM me your username I can check
EDIT
Never mind tracked it down looking now
 Matthew Wheeler
davidwalker900
who do you do your speed tests with sometimes it is does go to 42ms bt speed test and  speedtest.com and everywere interleaving is not a option on fibre its only avavible with nomal i think
Fixes: 187
Our tests have come back and confirmed there's no interleaving on your line.
Are you running these tests over a wired or wireless connection?
 Matthew Wheeler
St3
Aspiring Champion
Fixes: 5
wired thanks for looking mathew ill see how it goes over next day or so... im an online gamer so lower pings is very important too me ;P)
davidwalker900
is fibre have interleaving off all the time Matthew Wheeler
Fixes: 187
Hi David
It all depends on the individual line and how DLM has chosen to manage it. Some will have interleaving some won't but for most of our customers the difference isn't that noticeable.
 Matthew Wheeler
davidwalker900
Matthew Wheeler can you check mine see if i have it on or off
Fixes: 162
I've just tried to run the same test but for some reason it's not working. I'll try again later and post back.
 Chris Parr
 Plusnet Staff
Fixes: 187
@davidwalker
It looks like your due to move to a different provider on the 24th? This is preventing us from testing your line fully
 Matthew Wheeler
davidwalker900
yea i am move to a different provider on the 24th
St3
Aspiring Champion
Fixes: 5
traitor Tongue
rongtw
Fixes: 12
LOL ste you got Hijacked  Cheesy
St3
Aspiring Champion
Fixes: 5
ping seams ok at the mo, but last night was showing almost 40ms
St3
Aspiring Champion
Fixes: 5
ping creeping up again and lost all access to the internet around 12.20am today for around 10 mins.
