Ping and Speed fluctuations
enfluencexi
So whenever I'm downloading or playing a game the ping will fluctuate noticeably and I'm not sure what's causing this?
I've swapped out the terrible router and open reach modem for an all in one BT Home Hub 5 and followed the guide here.  Works fine and I'm not sure this is a problem with the router but maybe you can tell me what's up on your end? My friend who lives down the street and must be connected to the same exchange works fine although his ping is a little higher there is no fluctuations in his ping. It makes some games unplayable.
I've copied the event log from the hub. Not sure what to make of it though!
Time and date Message
18:39:35, 15 Dec. IN: BLOCK [16] Remote administration (TCP [194.63.140.74]:44641-​>[87.112.156.144]:22 on ppp3)
18:37:01, 15 Dec. BLOCKED 2 more packets (because of Advanced Filter Rule)
18:37:01, 15 Dec. OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath13_out/rule/0: UDP [0.0.0.0]:68-​>[255.255.255.255]:67 on ath13)
18:36:59, 15 Dec. BLOCKED 2 more packets (because of Advanced Filter Rule)
18:36:58, 15 Dec. OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath13_out/rule/0: UDP [0.0.0.0]:68-​>[255.255.255.255]:67 on ath13)
18:36:55, 15 Dec. BLOCKED 7 more packets (because of Advanced Filter Rule)
18:36:53, 15 Dec. OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath13_out/rule/0: UDP [10.94.39.210]:52360-​>[192.168.22.23]:53 on ath13)
18:36:53, 15 Dec. BLOCKED 12 more packets (because of Advanced Filter Rule)
18:36:53, 15 Dec. BLOCKED 2 more packets (because of Advanced Filter Rule)
18:36:52, 15 Dec. OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath13_out/rule/0: UDP [10.94.39.210]:68-​>[10.94.39.209]:67 on ath13)
18:34:14, 15 Dec. (424710.050000) Admin login successful by 192.168.1.124 on HTTP
18:32:16, 15 Dec. (424592.800000) New GUI session from IP 192.168.1.124
18:31:50, 15 Dec. OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_br1_out/rule/1: ICMP type 8 code 0 10.222.12.249-​>10.222.12.254 on br1)
18:31:49, 15 Dec. BLOCKED 6 more packets (because of Advanced Filter Rule)
18:31:48, 15 Dec. OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath13_out/rule/0: ICMPv6 type 143 code 0 0000:0000:0000:0000:0000:0000:0000:0000-​>ff02:0000:0000:0000:0000:0000:0000:0016 on ath13)
18:31:47, 15 Dec. BLOCKED 2 more packets (because of Advanced Filter Rule)
18:31:44, 15 Dec. OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath13_out/rule/0: UDP [0.0.0.0]:68-​>[255.255.255.255]:67 on ath13)
18:31:44, 15 Dec. BLOCKED 3 more packets (because of Advanced Filter Rule)
18:31:44, 15 Dec. OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath13_out/rule/0: ICMPv6 type 143 code 0 0000:0000:0000:0000:0000:0000:0000:0000-​>ff02:0000:0000:0000:0000:0000:0000:0016 on ath13)
18:26:55, 15 Dec. BLOCKED 2 more packets (because of Advanced Filter Rule)
18:26:54, 15 Dec. OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath13_out/rule/0: UDP [0.0.0.0]:68-​>[255.255.255.255]:67 on ath13)
18:26:51, 15 Dec. BLOCKED 7 more packets (because of Advanced Filter Rule)
18:26:50, 15 Dec. OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath13_out/rule/0: ICMPv6 type 143 code 0 fe80:0000:0000:0000:1c8c:f74b:6428:fffd-​>ff02:0000:0000:0000:0000:0000:0000:0016 on ath13)
18:26:50, 15 Dec. BLOCKED 10 more packets (because of Advanced Filter Rule)
18:26:49, 15 Dec. OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath13_out/rule/0: UDP [0.0.0.0]:68-​>[255.255.255.255]:67 on ath13)
18:26:44, 15 Dec. (424260.560000) OpenWiFi IPSec connection is up
18:26:40, 15 Dec. BLOCKED 6 more packets (because of Advanced Filter Rule)
18:26:36, 15 Dec. OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath13_out/rule/0: UDP [0.0.0.0]:68-​>[255.255.255.255]:67 on ath13)
18:26:35, 15 Dec. BLOCKED 3 more packets (because of Advanced Filter Rule)
18:26:34, 15 Dec. OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath13_out/rule/0: UDP [fe80:0000:0000:0000:1c8c:f74b:6428:fffd]:546-​>[ff02:0000:0000:0000:0000:0000:0001:0002]:547 on ath13)
18:26:32, 15 Dec. BLOCKED 6 more packets (because of Advanced Filter Rule)
18:26:31, 15 Dec. BLOCKED 3 more packets (because of Advanced Filter Rule)
18:26:30, 15 Dec. OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath13_out/rule/0: UDP [fe80:0000:0000:0000:1c8c:f74b:6428:fffd]:546-​>[ff02:0000:0000:0000:0000:0000:0001:0002]:547 on ath13)
18:26:30, 15 Dec. BLOCKED 8 more packets (because of Advanced Filter Rule)
18:26:28, 15 Dec. BLOCKED 10 more packets (because of Advanced Filter Rule)
18:26:27, 15 Dec. OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath13_out/rule/0: UDP [0.0.0.0]:68-​>[255.255.255.255]:67 on ath13)
18:25:27, 15 Dec. (424183.290000) Lease for IP 192.168.1.127 renewed by host iPhone (MAC 18:f6:43:1d:3b:3c). Lease duration: 1440 min
18:25:27, 15 Dec. (424183.290000) Device connected: Hostname: iPhone IP: 192.168.1.127 MAC: 18:f6:43:1d:3b:3c Lease time: 1440 min. Link rate: 54.3 Mbps
18:25:27, 15 Dec. (424183.200000) Lease requested
18:25:25, 15 Dec. (424181.070000) Device disconnected: Hostname: PS4-​e8-​61-​7e-​83-​d0-​95 IP: 192.168.1.131 MAC: e8:61:7e:83:d0:95
18:25:25, 15 Dec. (424181.070000) Device disconnected: Hostname: Unknown-​18-​2a-​7b-​51-​6b-​b6-​2 IP: 192.168.1.139 MAC: 18:2a:7b:51:6b:b6
18:25:22, 15 Dec. (424178.430000) Lease requested
18:25:21, 15 Dec. ath00: STA 18:f6:43:1d:3b:3c IEEE 802.11: Client associated
18:23:31, 15 Dec. IN: BLOCK [16] Remote administration (TCP [119.48.248.77]:11820-​>[87.112.156.144]:8080 on ppp3)
18:20:02, 15 Dec. (423858.770000) OpenWiFi IPSec connection is down
18:19:11, 15 Dec. BLOCKED 3 more packets (because of Advanced Filter Rule)
18:19:09, 15 Dec. OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath13_out/rule/0: ICMPv6 type 143 code 0 fe80:0000:0000:0000:42f3:08ff:fe67:788a-​>ff02:0000:0000:0000:0000:0000:0000:0016 on ath13)
18:19:09, 15 Dec. BLOCKED 2 more packets (because of Advanced Filter Rule)
18:19:08, 15 Dec. OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath13_out/rule/0: UDP [0.0.0.0]:68-​>[255.255.255.255]:67 on ath13)
18:19:04, 15 Dec. BLOCKED 3 more packets (because of Advanced Filter Rule)
18:19:03, 15 Dec. OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath13_out/rule/0: ICMPv6 type 143 code 0 0000:0000:0000:0000:0000:0000:0000:0000-​>ff02:0000:0000:0000:0000:0000:0000:0016 on ath13)
18:14:23, 15 Dec. IN: BLOCK [16] Remote administration (TCP [82.221.105.7]:20012-​>[87.112.156.144]:8443 on ppp3)
18:04:51, 15 Dec. BLOCKED 2 more packets (because of Advanced Filter Rule)
18:04:50, 15 Dec. OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath13_out/rule/0: UDP [0.0.0.0]:68-​>[255.255.255.255]:67 on ath13)
18:04:47, 15 Dec. BLOCKED 3 more packets (because of Advanced Filter Rule)
18:04:46, 15 Dec. OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath13_out/rule/0: ICMPv6 type 143 code 0 fe80:0000:0000:0000:36bb:26ff:febf:3744-​>ff02:0000:0000:0000:0000:0000:0000:0016 on ath13)
18:04:46, 15 Dec. BLOCKED 2 more packets (because of Advanced Filter Rule)
18:04:42, 15 Dec. OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath13_out/rule/0: UDP [0.0.0.0]:68-​>[255.255.255.255]:67 on ath13)
18:04:42, 15 Dec. BLOCKED 2 more packets (because of Advanced Filter Rule)
18:04:39, 15 Dec. BLOCKED 2 more packets (because of Advanced Filter Rule)
18:04:37, 15 Dec. OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath13_out/rule/0: UDP [0.0.0.0]:68-​>[255.255.255.255]:67 on ath13)
18:04:37, 15 Dec. BLOCKED 3 more packets (because of Advanced Filter Rule)
18:04:37, 15 Dec. OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath13_out/rule/0: ICMPv6 type 143 code 0 0000:0000:0000:0000:0000:0000:0000:0000-​>ff02:0000:0000:0000:0000:0000:0000:0016 on ath13)
18:02:40, 15 Dec. (422816.680000) OpenWiFi IPSec connection is up
18:02:33, 15 Dec. BLOCKED 4 more packets (because of Advanced Filter Rule)
18:02:32, 15 Dec. BLOCKED 2 more packets (because of Advanced Filter Rule)
18:02:32, 15 Dec. OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath13_out/rule/0: UDP [0.0.0.0]:68-​>[255.255.255.255]:67 on ath13)
18:02:32, 15 Dec. BLOCKED 3 more packets (because of Advanced Filter Rule)
18:02:28, 15 Dec. OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath13_out/rule/0: ICMPv6 type 143 code 0 0000:0000:0000:0000:0000:0000:0000:0000-​>ff02:0000:0000:0000:0000:0000:0000:0016 on ath13)
18:02:27, 15 Dec. BLOCKED 3 more packets (because of Advanced Filter Rule)
18:02:26, 15 Dec. BLOCKED 2 more packets (because of Advanced Filter Rule)
18:02:24, 15 Dec. OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath13_out/rule/0: UDP [0.0.0.0]:68-​>[255.255.255.255]:67 on ath13)
18:02:22, 15 Dec. BLOCKED 2 more packets (because of Advanced Filter Rule)
18:02:21, 15 Dec. OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath13_out/rule/0: UDP [0.0.0.0]:68-​>[255.255.255.255]:67 on ath13)
18:02:03, 15 Dec. BLOCKED 2 more packets (because of Advanced Filter Rule)
18:02:02, 15 Dec. OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath13_out/rule/0: UDP [0.0.0.0]:68-​>[255.255.255.255]:67 on ath13)
18:00:50, 15 Dec. IN: BLOCK [16] Remote administration (ICMP type 8 code 0 91.193.128.159-​>87.112.156.144 on ppp3)
17:50:29, 15 Dec. BLOCKED 2 more packets (because of Advanced Filter Rule)
17:50:28, 15 Dec. OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath13_out/rule/0: UDP [0.0.0.0]:68-​>[255.255.255.255]:67 on ath13)
17:49:06, 15 Dec. IN: BLOCK [16] Remote administration (TCP [93.185.118.28]:44358-​>[87.112.156.144]:22 on ppp3)
17:41:03, 15 Dec. OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.124]:59727-​>[185.31.128.208]:80 on ppp3)
17:37:26, 15 Dec. (421303.040000) NTP synchronization success!
17:32:16, 15 Dec. BLOCKED 3 more packets (because of ICMP replay)
17:32:15, 15 Dec. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 87.112.156.144-​>212.56.73.67 on ppp3)
17:26:48, 15 Dec. (420664.810000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any-​>9589, internal ports: 9589, internal client: 192.168.1.124
17:26:47, 15 Dec. BLOCKED 2 more packets (because of ICMP replay)
17:26:47, 15 Dec. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 87.112.156.144-​>192.229.233.25 on ppp3)
17:26:36, 15 Dec. (420653.240000) Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports: any-​>9589, internal ports: 9589, internal client: 192.168.1.124
17:25:43, 15 Dec. (420600.730000) Lease for IP 192.168.1.124 renewed by host DESKTOP-​KUDL1KV (MAC 50:46:5d:6a:77:95). Lease duration: 1440 min
17:25:43, 15 Dec. (420600.730000) Device connected: Hostname: DESKTOP-​KUDL1KV IP: 192.168.1.124 MAC: 50:46:5d:6a:77:95 Lease time: 1440 min. Link rate: 1000.0 Mbps
17:25:43, 15 Dec. (420600.610000) Lease requested
17:25:36, 15 Dec. (420593.240000) Wire Lan Port 1 up
17:25:33, 15 Dec. (420590.240000) Wire Lan Port 1 down
17:25:24, 15 Dec. (420581.240000) Wire Lan Port 1 up
17:25:21, 15 Dec. (420578.240000) Wire Lan Port 1 down
17:25:18, 15 Dec. (420575.240000) Wire Lan Port 1 up
17:24:33, 15 Dec. (420529.800000) Device disconnected: Hostname: PS4-​e8-​61-​7e-​83-​d0-​95 IP: 192.168.1.131 MAC: e8:61:7e:83:d0:95
17:24:33, 15 Dec. (420529.790000) Device disconnected: Hostname: PS4-​e8-​61-​7e-​83-​d0-​95 IP: 192.168.1.131 MAC: e8:61:7e:83:d0:95
17:24:33, 15 Dec. (420529.790000) Device disconnected: Hostname: Unknown-​18-​2a-​7b-​51-​6b-​b6-​2 IP: 192.168.1.139 MAC: 18:2a:7b:51:6b:b6
1 REPLY
enfluencexi
Re: Ping and Speed fluctuations
bump
