Ping all over the place
sspen63
I've just switched to plusnet from BT Infinity 2, my speed and everything is fine and my ping is low at times however it fluctuates a lot.
Pinging bbc.co.uk 5 times I see varations from 17ms to 70ms and playing CSGO my ping also fluctuates by about 30ms.
Any ideas?
12 REPLIES 12
Chris
Legend
Fixes: 169
Re: Ping all over the place
Are you using a wired or wireless connection?
I've just tested your line and it's detecting a potential issue in the local network, can you run through the troubleshooter here so we can do some more testing? https://faults.plus.net
sspen63
The troubleshooter wasn't very relevant to my issue but I've went through it anyway.
By a potential issue in the local network what do you mean?
hillyfields123
Probably referring to the 'last mile' from the exchange to your premises.
sspen63
I've suspected for a while now that there's been an issue with my line.
I get a lot of errors on the line no matter what device I use, what cables I use or even a new faceplate. An engineer came out last year when I complained at BT for a similar issue and couldn't find anything wrong...
hillyfields123
As in FEC errors?
Have you tried doing the Quiet Line Test? Call 17070 option 2 and check for any noise on the line. It should be completely silent.
sspen63
Line is perfectly quiet.
I've checked the stats on my HG612 and for 9 days uptime I have very low error count, not sure those are FEC errors though, think it was CRC.
Chris
Legend
Fixes: 169
Sorry if I missed it, but are you wired or wireless?
sspen63
Wired
Engineer came out and said the line was perfect.
A friend on sky fibre gets consistent low 20ms pings on CSGO whereas mine can sometimes be 30ms higher.
I tried changing the gateway I was connected to and it helped for a bit before my pings climbed back to the usual level again...
sspen63
Something is majorly wrong, I'm now getting rubberbanding effect in games where character will stutter forwards and backwards.
Here's my pingtest result....
MatthewWheeler
Fixes: 479
Our testing isn't showing any issues although you are maxing out your upload on a regular basis.
Have you made sure there's nothing running in the background when your carrying out a speedtest?
 Matthew Wheeler
sspen63
The only time I max out my upload is when uploading files for work.
Nothing was uploading when I ran that pingtest yesterday, nothing that I'm aware of anyway.
Still getting the same results today.
sspen63
As you can see my TBB chart is a joke, gaming is a laggy mess.
