Phone and Fibre gone off a few days after moving house
amy402
Our phone and fibre service moved on 14th Jan and seemed to be working ok.
Only a house move (Plusnet to Plusnet)
But we now have no dial tone and obviously no fibre.
I went through the phone troubleshooting / line check page and it says "Our checks show that your phone service is with another provider. To fix any problems you're experiencing you'll need to contact them."
https://www.plus.net/help/phone/phone-line-troubleshooting/
So pretty confused what the problem is?
Especially for it to work, then stop working?
Any help would be appreciated.
Thanks.
1 REPLY 1
Legend
Fixes: 220
Re: Phone and Fibre gone off a few days after moving house
Welcome to the forums @amy402 . I assume that the 'check' is wrong, and you pay Plusnet for both phone and fibre? If so, I suggest you try ringing them and asking that the records are checked and amended as required.
Whilst on that call, report your problems as well.
