Phone activated today but no fibre.
foxmiester
Hi i received a activation email at 5.50am the phone works but fibre doesn't. I plugged the hub 1 in and waited ten mins and nothing. Tried resetting the router and the lights go green then blue for 30 seconds then orange with the red B lit up. I signed up for the 76mb package.
Fixes: 65
Re: Phone activated today but no fibre.
It's unlikely the fibre will be activated yet. It usually needs an engineer to go to the local cabinet. They won' t start work until about 8:00. The phone activation is done remotely.
foxmiester
Thanks for the info MisterW
Fixes: 167
I do have some good news, the order has completed so I'm just activating your account now.
 Chris Parr
 Plusnet Staff
foxmiester
Thank you Chris
foxmiester
Hi Chris how long should activation take as it's still not working.
Fixes: 167
Your router is trying to connect with the wrong password, I've removed and readded the router to your account so this should push the correct details down to you. If it doesn't connect in 5 minutes, try a single factory reset and leave it to set up for 15 minutes.
 Chris Parr
 Plusnet Staff
foxmiester
Hi Chris all sorted now I forgot my password and changed it this morning to log in so my fault. But thanks for your time, just done a speed test and it's 69 down 19 up ping 10. The same as I was getting at BT so one happy customer. 😀
Fixes: 167
Glad to hear! Just let us know if you've got any questions.
 Chris Parr
 Plusnet Staff
