Personal alarm system slowing speed down.
dolanmorrison
With my Personal alarm system connected to the telephone socket our Fibre speed is 15 Mbps.With Alarm disconnected speed is 33Mbps.What is the answer.Thank You.
Router is the new Plusnet Hub.
Fixes: 60
Re: Personal alarm system slowing speed down.
it sounds like it isn't filtered
Fixes: 136
As Oldjim has mentioned is it filtered?
If you can send a photo of how you have it set up we may be able to advise better.
 Matthew Wheeler
dolanmorrison
Alarm now filtered and speed gone up to 33Mbps.Thank You.
