Periods of very high latency
- Re: Periods of very high latency
01-10-2017 8:10 PM
I have been noticing my fibre broadband appears to pause every now an again. Tonight I started a ping to www.plus.net and noticed strange results. About every 2 minutes the response time increases then goes back to reasonable again. I would be interested to know if anyone else is seeing this of if I have fault somewhere. Plus.net fibre broadband 80/20.
64 bytes from 212.159.9.2: icmp_seq=86 ttl=58 time=33.542 ms
64 bytes from 212.159.9.2: icmp_seq=87 ttl=58 time=53.335 ms
64 bytes from 212.159.9.2: icmp_seq=88 ttl=58 time=197.623 ms
64 bytes from 212.159.9.2: icmp_seq=89 ttl=58 time=103.686 ms
64 bytes from 212.159.9.2: icmp_seq=90 ttl=58 time=405.422 ms
64 bytes from 212.159.9.2: icmp_seq=91 ttl=58 time=27.693 ms
Request timeout for icmp_seq 92
Request timeout for icmp_seq 93
Request timeout for icmp_seq 94
64 bytes from 212.159.9.2: icmp_seq=92 ttl=58 time=3474.921 ms
64 bytes from 212.159.9.2: icmp_seq=93 ttl=58 time=3015.099 ms
64 bytes from 212.159.9.2: icmp_seq=94 ttl=58 time=2634.751 ms
64 bytes from 212.159.9.2: icmp_seq=95 ttl=58 time=2186.324 ms
64 bytes from 212.159.9.2: icmp_seq=96 ttl=58 time=2502.631 ms
64 bytes from 212.159.9.2: icmp_seq=97 ttl=58 time=2676.342 ms
64 bytes from 212.159.9.2: icmp_seq=98 ttl=58 time=3172.118 ms
64 bytes from 212.159.9.2: icmp_seq=99 ttl=58 time=2635.260 ms
64 bytes from 212.159.9.2: icmp_seq=100 ttl=58 time=2264.144 ms
64 bytes from 212.159.9.2: icmp_seq=101 ttl=58 time=1325.216 ms
64 bytes from 212.159.9.2: icmp_seq=102 ttl=58 time=433.657 ms
64 bytes from 212.159.9.2: icmp_seq=103 ttl=58 time=17.534 ms
64 bytes from 212.159.9.2: icmp_seq=104 ttl=58 time=18.924 ms
64 bytes from 212.159.9.2: icmp_seq=105 ttl=58 time=27.176 ms
64 bytes from 212.159.9.2: icmp_seq=106 ttl=58 time=58.967 ms
64 bytes from 212.159.9.2: icmp_seq=107 ttl=58 time=32.493 ms
02-10-2017 2:53 PM
Hi Ben, sorry to hear you're having broadband issues. I've checked through the connection this side and everything is looking spot on from here to the router with the full 80Mbps download and 20 Mbps upload. No errored seconds showing and no drops in the last 5 days. When doing the ping tests, are you doing them over a wired or wireless connection? As if wired this could hint that you're getting wireless interference and if your noticing fluctuating speeds there also we'd send the relevant guide on how to best tweak the wireless to suite the property.
If it's on a wired connection your seeing this then could you please do a ping test to a few other sites to see what they are looking like.
Kind regards,
Ben
20-12-2017 8:17 PM
I am getting terrible fluctuating latency readings. The internet is not useable. This has happened in the last week having moved over to fibre. Really, really disappointed. I have undertaken a number of speed tests and evrything is fluctuating all over teh place inclusing both doenloand and upload speeds but the one that is really frustrating me is the time it take st oget on a link - alot of teh time it times out. What the hell is going on?
22-12-2017 12:00 AM
