Paying for 50mb minimum, receiving 2.3
- Paying for 50mb minimum, receiving 2.3
01-09-2021 10:43 PM
Any suggestions? As to why it’s so bad. I get my first bill in 2 days, I’m really not happy with the first two days of my sub. Yesterday I had 20. Today 2.3.
Re: Paying for 50mb minimum, receiving 2.3
01-09-2021 11:04 PM
How about posting some router stats, log into the router, go to the Advanced/Troubleshooting/Help Desk tab and post that, hiding your username.
Then let us know how and waht with you are getting those speeds.
02-09-2021 5:12 AM
@Chargrange check that the username configured in the router is correct and not setup@plusdsl.net
1. Connect a device onto the router's WiFi or plug a laptop/PC into the router using an ethernet cable
2. Go to the router's homepage at http://192.168.1.254
3. Click on the Advanced Settings tab
4. Type in the admin password found from the back of the router and click the OK button
5. Click on the Continue to Advanced Settings button then the Broadband tab
6. If there's a Disconnect button, click that
7. Change the username to the broadband username in the format of username@plusdsl.net If you can't remember this I'd check for any emails PLUSNETsent you as they'd add the username to the top of the email.
8. Type in the account password, this can be reset here: https://www.plus.net/forgotpassword/ if needed.
9. Hit the Connect button.
02-09-2021 8:18 AM
Good morning @Chargrange
Thanks a lot for reaching out. did the authentication steps above resolve this issue for you? I'd run a test on the line to see if you're logged into the router but I can't seem to locate your account from your Forum profile. Feel free to send me a PM with the account username if you're still having problems.
12-09-2021 5:19 PM
Hi Adam, I don't know how to reply to you directly?
What information would you need, its becoming frustrating, I decided to move across but wifi on phones, laptops and ps4 have been dramatically slower.
What information do you need? this isn't the account for the log in, just one I made to speak.
12-09-2021 5:27 PM
@Chargrange I don't think Adam is in today, and to get a reply to you quickly :- if you click his avatar on the left of his post it will open a tab on the right to allow you to send him the message.
He needs your Account user name.
12-09-2021 5:36 PM
Hi Jab, Thanks for replying, I've left him the information,
Do you know anyone who is in that would be able to sort this?
12-09-2021 5:40 PM
There's only one other staffer in today - and he is working through outstanding queries, unlikely to get to you today, but Adam should be back tomorrow.
12-09-2021 5:43 PM
No worries, Thank you!
12-09-2021 8:27 PM
Hi @Chargrange
I'm sorry to see you're having issues with your speed.
I've picked up the private message you've sent Adam, and tested your line. From what I can see the tests are showing your router's getting a download speed that's been stable at 68.7mbps with no drops for the last 11 days.
I suspect the issue may be more to do with the wireless signal around your home, so I'd recommend going through some wireless troubleshooting steps explained Here. If you can though plug your laptop into the router using an ethernet cable and run a speed test, that'll tell you if the issue is definitely to do with WiFi or there's another issue at hand.
