Path Mode Interleave in a new vdsl circuit
ronnieshamash
Hi i just been upgraded from adsl to vdsl2 a few hour ago, i am using a Draytek 2860ln router.
since the switchover today i get max sync speeds , but any speedtest i run it is around the 15 mbit up/ 55-60 mbit down range
looking my dsl stats (attached)
path mode shows interleave with
ATU-R Information
        Type:ADSL2/2+
        Hardware:Annex A
        Firmware:05-07-06-0D-01-07
        Power Mngt Mode:DSL_G997_PMS_L0
        Line State:SHOWTIME
        Running Mode:17A
        Vendor ID:b5004946 544e0000
ATU-C Information
       Vendor ID:b5004244 434da4a1 [BDCM]
Line Statistics
 Downstream            Upstream
Actual Rate80000Kbps19999Kbps
Attainable Rate101298Kbps35074Kbps
Path ModeInterleaveFast
Interleave Depth12841
Actual PSD0. 4dB13. 8dB
 Near End                 Far End
TrellisONON
BitswapONON
ReTx0 0
SNR Margin7dB15dB
Attenuation11dB13dB
CRC732
FECS4203s155s
ES1s8s
SES0s1s
LOSS0s0s
UAS30s214063s
HEC Errors00
RS Corrections00
LOS Failure00
LOF Failure00
LPR Failure00
NCD Failure00
LCD Failure00
NFEC25473
RFEC1616
LYSMB537425779
Is there anything i can do to improve it or do we have to get openreach to come back and do something at the cabinet that is an arm length away from my property
1 REPLY 1
RichardB
Champion
Fixes: 30
Re: Path Mode Interleave in a new vdsl circuit
Hi @ronnieshamash,
It is normal for DLM on a new VDSL circuit to default to interleaving.
Give DLM a few days to check the error rates on the line and all being well it should change to fast path.
As you posted a couple of days before I replied DLM may have alreday acted.
Regards
Richard
