Packet loss, slow speeds and tcp reset attacks.
- Packet loss, slow speeds and tcp reset attacks.
15-12-2020 2:38 PM
I'm currently trying to update a game on my Xbox one and getting a whopping 534kbps on a line syncing at 77mbps(connected via ethermet).
Re: Packet loss, slow speeds and tcp reset attacks.
18-12-2020 6:03 PM
Peak hour streaming is pretty much impossible.
It says something when I'm regretting leaving talktalk who provided a fault free 18 months previously.
Are the forums monitored by plusnet staff or is it customer based support?
18-12-2020 7:59 PM
Hi @nos911
Plunset staff used be more active in the forum than they are now.
So you are more likely to get a customer response, like this one.
Can you post an example tracert or traceroute, depending on your OS, to the BBC and one to the gaming server you use?
Are you connecting via WiFi?
Is so could you please test on a PC connected by Ethernet to the router?
Regards
Richard
19-12-2020 8:46 AM
As mentioned in my previous posts I am connected using Ethernet cable and the pings are huge and the speeds very low, I have tried multiple games(fortnite, warzone, Battlefield 4,1 &5, Rainbow six seige and Black ops cold war), I get rubber banding, very slow rendering and on the server browsers my ping to European servers is 1 or 2 bars out of 5(shows red, on a healthy connection it would be 5 out of 5 and green).
I'm either on a very congested line/exchange or something is very wrong with plusnets network, the last time I experienced anything like this was with Vodafone who had to let me leave penalty free after just 2 months of service because it would take up to 6 months to fix(very congested line).
19-12-2020 10:10 PM - edited 19-12-2020 10:11 PM
From just after 9am till 7 minutes ago my throughput was at best 22mbps and at worst 467kbps(again test vis ethernet and wireless) with my ping being anywhere from 200ms to 865ms with packet loss upto 67%, after 10pm everything is back to normal.
So either im suffering servere peak time congestion or Plusnet are traffic shaping/managing at peak times, I guess I will have to call and see what they say, but I feel I will have to leave and go back to TalkTalk.
