Packet loss + request gea test
St3
Aspiring Champion
Fixes: 5
I was getting bad packet loss and speed reduction but after jumping gateway it now seams to be improving.  Also can i request a GEA TestMy Broadband Ping - plusnet-bgm
My Broadband Speed Test
Fixes: 190
Re: Packet loss + request gea test
I've attached your GEA test below
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 68.4 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Estimated Line Length In Metres 439.4
Upstream Rate Assessment Very Good
Downstream Rate Assessment Good
Interference Pattern Regular Interference Observed Daily
Interference Duration Longest Occurrence From 13:45 to 13:00
Interference Location Customer Premise
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-80M Downstream 3dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2018-06-13T10:00:00
Parameters MIN MAX AVG
Down Stream Line Rate 72.1 Mbps 72.1 Mbps 72.1 Mbps
Up Stream Line Rate 20.0 Mbps 20.0 Mbps 20.0 Mbps
Up Time 898.0 Sec 900.0 Sec 899.9 Sec
Retrains 0.0 0.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2018-06-26T08:29:12Z 2018-06-26T08:44:12Z
Ingress Code Violation 3 1
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
 Matthew Wheeler
St3
Aspiring Champion
Fixes: 5
Thank you
