Packet Loss
- Packet Loss
Packet Loss
20-03-2019 10:10 PM
For months my connection has been stable and without issue however since around 1 week ago I've been experiencing packet loss mainly during peak times but at other times also. Any help with this issue would be greatly appreciated.
Re: Packet Loss
21-03-2019 9:14 AM
Morning @Welpz,
Thanks for getting in touch with us.
So that we can help to narrow down where the problem lies, please can you confirm whether or not the same issue occurs across all of your devices? Please can you also confirm if the same issue occurs via Ethernet cable connected devices?
I've not been able to access your account from the information on your profile, please could you PM me your account username so I can run some tests on your service.
Thank you.
Re: Packet Loss
25-03-2019 10:03 PM
After providing the necessary information i haven't received any followup and the issue still persists.
Re: Packet Loss
26-03-2019 9:24 AM
Hi @Welpz
Thanks for providing your username - my apologies for the delay in coming back to you.
I've tested your connection and everything is looking good from this side. Your connection is stable and you're in sync at 33mb/s which is actually above the estimates for your line.
How are you seeing this packet loss? Does it occur against a wired and wifi connection? Does it occur on all devices? When the issue occurs, if you ping and trace route www.bbc.co.uk what are the results? (post them here).
Let us know
Best wishes
Dave
Re: Packet Loss
28-03-2019 8:23 PM
Results below, issue seems to be more prevalent during the evening but exists at other times also.
Pinging bbc.co.uk [151.101.0.81] with 32 bytes of data:
Reply from 151.101.0.81: bytes=32 time=16ms TTL=57
Reply from 151.101.0.81: bytes=32 time=14ms TTL=57
Request timed out.
Reply from 151.101.0.81: bytes=32 time=13ms TTL=57
Reply from 151.101.0.81: bytes=32 time=15ms TTL=57
Request timed out.
Reply from 151.101.0.81: bytes=32 time=23ms TTL=57
Ping statistics for 151.101.0.81:
Packets: Sent = 30, Received = 28, Lost = 2 (6% loss),
Approximate round trip times in milli-seconds:
Minimum = 13ms, Maximum = 23ms, Average = 13ms
Tracing route to bbc.co.uk [151.101.64.81]
over a maximum of 30 hops:
1 1 ms <1 ms <1 ms dsldevice.lan [192.168.1.254]
2 * * * Request timed out.
3 * * * Request timed out.
4 14 ms 14 ms 14 ms 136.hiper04.sheff.dial.plus.net.uk [195.166.143.136]
5 14 ms 15 ms 14 ms 195.99.125.134
6 15 ms 15 ms 15 ms peer7-et-3-1-5.telehouse.ukcore.bt.net [109.159.252.236]
7 15 ms 14 ms 14 ms peer5-te0-9-0-32.telehouse.ukcore.bt.net [195.99.126.81]
8 17 ms 14 ms 15 ms 151.101.64.81
Trace complete.
Re: Packet Loss
28-03-2019 9:11 PM
Hi @Welpz, thanks for providing that,
The trace route and ping looks all good - the latency looks low and trace route completed.
Can you advise where you are seeing this packet loss and if possible provide a screenshot? As Dave's mentioned could you advise if this occurs across all devices and if you are seeing this over both wired and wireless connections?
Re: Packet Loss
29-03-2019 7:43 PM - edited 29-03-2019 7:44 PM
The ping test provided demonstrates the packet loss does it not?
The issue occurs across all devices whether wired or wireless, screenshots demonstrating the loss is included.
Re: Packet Loss
29-03-2019 8:41 PM
To my eye there's no packet loss showing and the latency is low. You'll always see some hops timing out as they'll be prioritising network traffic rather than simply responding back to your ping request.
We'll need more diagnostic information in order to further investigate this I'm afraid.
Can you setup a ThinkBroadband Quality Monitor via the instructions found Here please?
Once you've done this post up the graph and we'll be happy to take a look.
I've also checked your usage and I can see quite a lot of data being transferred. This would inevitably cause you to see higher latency and some packet loss as your connection is being used.
Do you see the problems with no other devices using the broadband and no background tasks open on the device you're using? Also, is there any noise on your phone line? If so that would need to be reported to your phone provider.
