Packet Loss
- Packet Loss
Packet Loss
08-11-2016 8:55 PM - edited 08-11-2016 8:56 PM
For the past week or two I've started noticing random packet loss, which is effecting online gaming and voice comms (TeamSpeak, Skype etc) and its becoming really frustrating. Not sure why this problem has started but I've noticed a few other people posting here about the exact same thing so I thought I'd add my problem to the pile and hopefully Plusnet can help out.
I left MTR running for a good while so I'll attach the file below showing the packet loss.
Not had any loss in speeds or anything
Re: Packet Loss
08-11-2016 9:26 PM
I have noticed exactly the same thing. I notice it mainly when using VOIP. I previously had zero issues with this.
If I run ping tests I am dropping random packets.
I definitely think there is a problem here as I have had this fibre connection for nearly 2 years and never had packet loss issues before. The connection itself is rock solid and never drops, it is an issue of packet loss.
Plusnet - any comments on this please?
Re: Packet Loss
08-11-2016 9:34 PM
Same, it's getting infuriating and it's been with in the same time frame. My read is just as horrible. Think it's time to swap.
Re: Packet Loss
08-11-2016 10:12 PM
same here for over a week , random freeze / lag on game , my friends on mumble saying i'm laging , speed is good , when i do ping test , 0 packet loss but i think its more random packet loss then stabilize again , i have some jitter tonight ,i will reach out to them tomorrow
Re: Packet Loss
08-11-2016 11:15 PM
Same here, about a week too. It is soooo annoying. I lost a really decent character today on DayZ. I was in the middle of a firefight when the packet dropped, kicking me off the server and giving my enemy chance to kill me. It really p**sed me off.
Re: Packet Loss
09-11-2016 9:06 AM
As I am new to PlusNet, can you tell me if their support staff actively participate in this forum, or are we just discussing this among ourselves without any hope of anything being done?
(you will see I have posted my experience using PS4 COD BO3, continually glitching and disconnects)
This appears to be the same behavior as you guys are reporting. Could it be regional? I am in Berkshire (RG)
Re: Packet Loss
09-11-2016 9:57 AM
I am in the North of Scotland so if it is regional, it covers a very big region!
Re: Packet Loss
09-11-2016 2:13 PM
I've been experiencing packet loss for the last few weeks as well... As you can see on the 7th, I was experiencing quite a bit of packet loss, then after the downtime (apparently this was an issue with the local network) the packet loss disappeared. The 8th was pretty similar, however after a resync today the packet loss is back. I also have a static IP - I've seen a few people say that this is causing issues.
Re: Packet Loss
09-11-2016 2:32 PM
I'm on dynamic IP and getting the same problems so don't think it's limited to static IPs.
Re: Packet Loss
09-11-2016 2:34 PM
Although I too have static, I think it is a red herring, as I only added it on Sunday, and have been experiencing this for a couple of weeks.
Re: Packet Loss
09-11-2016 3:00 PM
Craigy, thanks for sharing your thinkbroadband quakity monitor graphs. I was wondering how I could prove my experience, and it looks perfect. I have setup a monitor but it appears I am getting 100% packet loss. Did you have to configure the Plusnet router?
Re: Packet Loss
09-11-2016 3:02 PM
@chrizk I don't use the Plusnet supplied router so I can't help with that I'm afraid
Re: Packet Loss
09-11-2016 3:06 PM
@chrizk - I've just read in another thread that some Plusnet routers do not respond to pings which may explain what you're seeing.
Re: Packet Loss
09-11-2016 3:16 PM
Re: Packet Loss
09-11-2016 3:55 PM
Thanks @Browni, thinkbroadband came back to me really quickly and said the same thing, referencing the following article (no intention to use custom firmware ...at this stage...)
Really disappointed that such a great monitor from thinkbroadband can't be used directly with Plusnet (it would have been nice and easy).
Great suggestion to use another device (annoyingly I will have to plug something straight into the router, which is currently using all Ethernet ports)
Not too keen to use DMZ, but 'needs must' ...come on PlusNet, why should I have to create a security loophole to workaround a restriction you force on us?
