Packet Loss Issue
Cameron2310
Packet Loss Issue
Hey there, I'm currently unable to do any streaming or online gaming at the moment due to recent internet issues. I've done speed tests and they look completely fine, with low ping and reliable down/up speeds. I think it might be due to packet loss/exceeding TTL. Incidentally, a friend of mine who is also with PlussNet only half a mile away is also describing the same issues with being able to browse the net okay, but unable to game on-line.
http://imgur.com/a/DZRnO
Here's a few images of some of the tests I've done. I'll upload a wire shark test if necessary.
Thanks in advance for any help you guys can provide me Smiley
RichardB
Fixes: 4
Re: Packet Loss Issue
Hi
The "packet loss" highlighted /ringed in red is not showing packet loss.
It is showing that a router, within PNs network, is not replying to the ping requests.
The router is (correctly) forwarding the packets onto subsequent hops/routers as can be seen by zero packet loss from the destination.
Were the loss to persist beyond that router to all subsequent hops then that would be packet loss.
Regards
Richard
Cameron2310
I see, thanks for the quick reply. I guess I'll try to reset my router/use a different one to see if it makes a difference Smiley
Fixes: 385
I'm struggling to find your account from your forum details, mind PMing me your username?
Cheers,
Anoush
RichardB
Fixes: 4
Changing Your home router will not chnage the behaviour of the "industrial scale" routers used inside PNs data centres.
The PN routers lack of response to a ping will not cause you issues.
There is a similar question/thread over at
https://community.plus.net/t5/Fibre-Broadband/Packet-loss-issue/m-p/1451354#M61248
Cameron2310
My username? On the forums, it's Cameron2310 but I feel like that isn't what you're looking for. The username created when joining plus-net was [Removed] I think but that was for another household member. Smiley
Moderator's note by Mike (Mav): Personal information removed from a public forum to an area that staff can see.
Cameron2310
Ah, thanks for the link. I was also thinking that the 141.hiper04.sheff.dial.plus.net.uk server was the problem from my WinMTR test but, as you said, it's just because the server is prioritizing routing traffic instead of pinging.
Cameron2310
Just did a pingplotter test, and it shows that there's a 30% packetloss from dsldevice.lan. I assume that's my router, as it's the first hop? Could this be the issue?
http://imgur.com/a/uTsZl
Edit; These might help http://imgur.com/a/CkcT7
Fixes: 189
Those links aren't working for me.
Can you attach them to your next post on here?
 Matthew Wheeler
Fixes: 11
Both of those links work for me @MatthewWheeler
RichardB
Fixes: 4
Hi
The links worked for me.
Looking at the pingplotter picture it shows a number of intermediate devices/IPs not responding to pings but the packets  are routed to the destination IP which is reporting a 0.6% packet loss.
Looking at the windows tracert to what appears to be a google IP address I cannot see any packet loss.
You could try MTR and see what that reports if you set it ping the BBC
It can be download from http://winmtr.net/
and invoked using mtr www.bbc.co.uk
Richard
If the final IP shows no packet loss then whatever the intermediate steps/IPs report is nothing to worry about.
Fixes: 180
I'm afraid access to imgur is blocked internally in the office.
@Cameron2310 - Are you able to post the images here in the thread? Thanks.
 Harry Beesley
Cameron2310
Of course. Here's all the screenshots so far of different tests;
Edit; I'm now only getting 20mbps down (was 36) and only 0.05 up (was about 1.5)
Cameron2310
Hi Richard, this is what I got when using WinMTR with www.bbc.co.uk as the host.
Fixes: 385
Thanks for your private message Cameron, apologies for the delay.
Testing the line isn't identifying any issues.
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0003
Description No problem found, OAM test is not currently supported on this line.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 40.0 Mbps
Upstream Speed 2.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 1088.8
Upstream Rate Assessment Very Good
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Current 15Min Bin Retrains 0
Last 15Min Bin Retrains 0
Profile Name 0.128M-40M Downstream, Retransmission Low - 0.128M-2M Upstream, Error Protection Off
Are you using a wireless or wired connection?
