Packet Loss Again
Packet Loss Again
Anybody else seeing this today? Started at 4PM yesterday, rebooted router and modem at 10AM this morning too.
http://www.thinkbroadband.com/ping/share/bd71a9cb7a717046fffd7f176e07ccfd-25-12-2016.html
3Mb FTTC
jstallan
Re: Packet Loss Again
I think I've got it again. Performance dropped off the cliff at dead on 2pm today. Gateway hopping is proving useless. I'm on a static ip and the old network. Called PN and now awaiting call back.
Plusnet Staff
Plusnet Staff
Fixes: 116
Hello @godsell4
Sorry to hear you're having issues with your broadband again. I've been testing your line and not been picking up any issues:
Sync Status In Sync
Downstream Speed 4.8 Mbps
Upstream Speed 1.1 Mbps
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2016-12-26T17:30:17Z 2016-12-26T17:45:17Z
Ingress Code Violation 0 0
Egress Code Violation 3 0
Errored Seconds 2 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
The connection also is pretty stable...
...however, it does look like the reboot of your router didn't actually drop the PPP session. There could be a stale session somewhere. I'd probably advise to power the router off for 65 minutes and back on again.
@jstallan - Your connection is looking rather flaky from 2pm:
I'm not picking up any issues though:
Sync Status In Sync
Downstream Speed 40.0 Mbps
Upstream Speed 2.0 Mbps
Voice Line Test Result Pass
My best advice would be to test your router from the test socket (if you aren't already). This guide will explain how to do this: https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
And then if you need to, you can raise this as a fault at http://faults.plus.net
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
jstallan
Thanks for looking at my issue. Test socket makes no difference. TBB graph looks horrendous as it all kicked off at 2pm. I'm posting this from my phone as BB is unusable.
I've got online exams to take now and starting to wonder what the hell I'm going to do as the current connection is unusable.
http://www.thinkbroadband.com/ping/share/0fb146ac376c65a5f4408eba69903256-26-12-2016.html
Fixes: 31
Its probably going to need an engineer visit, so if you have not already done it then rise a fault via the Link above.
Plusnet Staff
Plusnet Staff
Fixes: 116
@jstallan - I'd probably advise to report this to us at http://faults.plus.net if you haven't already.
I'll see what I can do tomorrow to progress this to an engineer, however, I can't guarantee a quick fix because of engineer availability due to the past and upcoming bank holidays. Sad
 Plusnet Staff
jstallan
I reported it by phone late yesterday afternoon. Ticket 140735824
Any additional help in escalation would be appreciated.
@Anoush think my issues is REIN again, something outside my property this time.
3Mb FTTC
jstallan
@Anoush discovered it was a rogue PC on my network transmitting data that saturated my connection. Thanks for the help
@godsell4 Apologies for hi-jacking your thread. Good luck with the REIN
Plusnet Staff
Plusnet Staff
Fixes: 116
@godsell4, My tests aren't picking up any significant errors, and the connection is pretty much stable.
 Plusnet Staff
