PS3 Connection
Wizhunter
PS3 Connection
Hi Guys
No Internet this morning so i rang plusnet up and they told me it was a faulty router and they said they would send me a new one.Anyway they set up a connection so i could use my PC so i was quite happy until tonight..Went to switch the PS3 on and no connection to it ?..So if any of you guys have any idea's it would be much appreciated
Wizhunter
1 REPLY
Fixes: 5
Re: PS3 Connection
It sounds like you've been given a direct connection between the modem and PC until your new router arrives. If I'm right, this would mean you'd only have access to one device (the PC) at once. I think you'd be best waiting for the new router to arrive before attempting to use the ps3.
 Tony T
