PPPoE is down after XX minutes uptime/PPP LCP Send Termination Request [User request]
- PPPoE is down after XX minutes uptime/PPP LCP Send...
04-02-2019 6:27 PM
17:55:04, 01 Feb. | ( 1393.920000) PPPoE is down after 19 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 - Down)] |
17:55:01, 01 Feb. | ( 1391.370000) PPP LCP Send Termination Request [User request] |
05:20:48, 04 Feb. |
( 176.120000) CWMP: session completed successfully |
05:20:47, 04 Feb. |
( 175.940000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo |
05:20:45, 04 Feb. |
( 173.330000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
05:20:45, 04 Feb. |
( 173.330000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE' |
05:20:15, 04 Feb. |
( 143.000000) CWMP: session closed due to error: HTTP authentication error |
05:20:15, 04 Feb. |
( 143.000000) CWMP: HTTP authentication fail from https://dbtpnhdm.bt.mo |
05:20:11, 04 Feb. |
( 140.000000) NTP synchronization success! |
05:20:08, 04 Feb. |
( 136.300000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
05:20:08, 04 Feb. |
( 136.290000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE' |
05:20:07, 04 Feb. |
( 135.670000) NTP synchronization start |
05:20:06, 04 Feb. |
( 134.730000) WAN operating mode is VDSL |
05:20:06, 04 Feb. |
( 134.730000) Last WAN operating mode was VDSL |
05:20:05, 04 Feb. |
( 133.600000) PPP IPCP Receive Configuration ACK |
05:20:05, 04 Feb. |
( 133.520000) PPP IPCP Send Configuration ACK |
05:20:05, 04 Feb. |
( 133.510000) PPP IPCP Receive Configuration Request |
05:20:05, 04 Feb. |
( 133.490000) PPP IPCP Send Configuration Request |
05:20:05, 04 Feb. |
( 133.480000) PPP IPCP Receive Configuration NAK |
05:20:05, 04 Feb. |
( 133.460000) PPP IPCP Send Configuration Request |
05:20:04, 04 Feb. |
( 132.530000) PPPoE is up - Down Rate=40000Kbps, Up Rate=9999Kbps; SNR Margin Down=7.4dB, Up=7.8dB |
05:20:04, 04 Feb. |
( 132.520000) CHAP authentication successful |
05:20:04, 04 Feb. |
( 132.350000) CHAP Receive Challenge |
05:20:04, 04 Feb. |
( 132.350000) Starting CHAP authentication with peer |
05:20:04, 04 Feb. |
( 132.340000) PPP LCP Receive Configuration ACK |
05:20:04, 04 Feb. |
( 132.330000) PPP LCP Send Configuration ACK |
05:20:04, 04 Feb. |
( 132.320000) PPP LCP Send Configuration Request |
05:20:04, 04 Feb. |
( 132.320000) PPP LCP Receive Configuration Request |
05:20:04, 04 Feb. |
( 132.220000) CHAP Receive Challenge |
05:20:04, 04 Feb. |
( 132.220000) Starting CHAP authentication with peer |
05:20:04, 04 Feb. |
( 132.220000) PPP LCP Receive Configuration ACK |
05:20:04, 04 Feb. |
( 132.200000) PPP LCP Send Configuration Request |
05:20:04, 04 Feb. |
( 132.200000) PPP LCP Receive Configuration Reject |
05:20:03, 04 Feb. |
( 132.190000) PPP LCP Send Configuration ACK |
05:20:03, 04 Feb. |
( 132.190000) PPP LCP Receive Configuration Request |
05:20:03, 04 Feb. |
( 132.190000) PPP LCP Send Configuration Request |
05:19:15, 04 Feb. |
( 83.300000) PTM over DSL is up |
05:19:04, 04 Feb. |
( 72.840000) CWMP: session closed due to error: Could not resolve host |
05:19:04, 04 Feb. |
( 72.820000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
05:19:04, 04 Feb. |
( 72.810000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE' |
05:18:46, 04 Feb. |
ath10: STA cc:9e:a2:c3:2f:72 IEEE 802.11: Client associated |
05:18:34, 04 Feb. |
( 42.490000) CWMP: session closed due to error: Could not resolve host |
05:18:34, 04 Feb. |
ath00: STA 28:ad:3e:0e:42:3c IEEE 802.11: Client associated |
05:18:30, 04 Feb. |
( 39.110000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
05:18:30, 04 Feb. |
( 39.100000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE' |
05:18:30, 04 Feb. |
( 38.790000) CWMP: Initializing transaction for event code 1 BOOT |
05:18:29, 04 Feb. |
( 37.670000) WiFi auto selected channel 48 |
05:18:29, 04 Feb. |
( 37.670000) 36- 92::40- 92::44- 92::48- 91::52- 91::56- 90::60- 90::64- 90::100- 91::104- 92::108- 92::112- 93::116- 93::120- 95::124- 95::128- 95 |
05:18:29, 04 Feb. |
( 37.670000) 5 GHz Wireless: Rescan, Reason: 'Power- up' |
05:18:29, 04 Feb. |
( 37.670000) WiFi auto selected channel 1 |
05:18:29, 04 Feb. |
( 37.660000) 1- 96::2- 96::3- 95::4- 96::5- 96::6- 96::7- 97::8- 97::9- 98::10- 98::11- 98::12- 99::13- 98 |
05:18:29, 04 Feb. |
( 37.660000) 2.4 GHz Wireless: Rescan, Reason: 'Power- up' |
05:18:28, 04 Feb. |
( 37.010000) WAN Auto- sensing running. |
05:18:24, 04 Feb. |
( 32.430000) System up, firmware version: 4.7.5.1.83.8.263 |
05:18:20, 04 Feb. |
( 28.570000) WPA2 mode selected |
05:18:20, 04 Feb. |
( 28.570000) WPS enabled |
05:18:18, 04 Feb. |
( 26.670000) WPA2 mode selected |
05:18:18, 04 Feb. |
( 26.670000) WPS enabled |
05:18:09, 04 Feb. |
( 17.990000) System start |
05:08:57, 04 Feb. |
( 328.850000) NTP synchronization success! |
05:08:55, 04 Feb. |
( 326.920000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
05:08:55, 04 Feb. |
( 326.910000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE' |
05:08:55, 04 Feb. |
( 326.290000) NTP synchronization start |
05:08:54, 04 Feb. |
( 325.370000) WAN operating mode is VDSL |
05:08:54, 04 Feb. |
( 325.370000) Last WAN operating mode was VDSL |
05:08:53, 04 Feb. |
( 324.230000) PPP IPCP Receive Configuration ACK |
05:08:53, 04 Feb. |
( 324.130000) PPP IPCP Send Configuration ACK |
05:08:53, 04 Feb. |
( 324.130000) PPP IPCP Receive Configuration Request |
05:08:52, 04 Feb. |
( 324.050000) PPP IPCP Send Configuration Request |
05:08:52, 04 Feb. |
( 324.040000) PPP IPCP Receive Configuration NAK |
05:08:52, 04 Feb. |
( 324.020000) PPP IPCP Send Configuration Request |
05:08:51, 04 Feb. |
( 323.070000) PPPoE is up - Down Rate=40000Kbps, Up Rate=9999Kbps; SNR Margin Down=7.3dB, Up=7.8dB |
05:08:51, 04 Feb. |
( 323.060000) CHAP authentication successful |
05:08:51, 04 Feb. |
( 322.970000) CHAP Receive Challenge |
05:08:51, 04 Feb. |
( 322.970000) Starting CHAP authentication with peer |
05:08:51, 04 Feb. |
( 322.960000) PPP LCP Receive Configuration ACK |
05:08:51, 04 Feb. |
( 322.950000) PPP LCP Send Configuration ACK |
05:08:51, 04 Feb. |
( 322.950000) PPP LCP Send Configuration Request |
05:08:51, 04 Feb. |
( 322.940000) PPP LCP Receive Configuration Request |
05:08:51, 04 Feb. |
( 322.790000) CHAP Receive Challenge |
05:08:51, 04 Feb. |
( 322.790000) Starting CHAP authentication with peer |
05:08:51, 04 Feb. |
( 322.790000) PPP LCP Receive Configuration ACK |
05:08:51, 04 Feb. |
( 322.780000) PPP LCP Send Configuration Request |
05:08:51, 04 Feb. |
( 322.770000) PPP LCP Receive Configuration Reject |
05:08:51, 04 Feb. |
( 322.760000) PPP LCP Send Configuration ACK |
05:08:51, 04 Feb. |
( 322.760000) PPP LCP Receive Configuration Request |
05:08:51, 04 Feb. |
( 322.760000) PPP LCP Send Configuration Request |
05:08:22, 04 Feb. |
( 293.700000) CWMP: Initializing transaction for event code 4 VALUE CHANGE |
05:08:12, 04 Feb. |
( 292.680000) CWMP: session closed due to error: Could not resolve host |
05:08:12, 04 Feb. |
( 292.680000) PPP LCP Send Termination Request [PPPoE PADT received] |
05:08:12, 04 Feb. |
( 292.680000) PPPoE is down after 1 minutes uptime [Disconnected] |
05:08:10, 04 Feb. |
( 292.680000) PPP LCP Send Termination Request [Peer not responding] |
05:08:03, 04 Feb. |
( 274.230000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
05:08:03, 04 Feb. |
( 274.230000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE' |
05:07:32, 04 Feb. |
( 243.900000) CWMP: session closed due to error: Could not resolve host |
05:07:32, 04 Feb. |
( 243.900000) NTP synchronization failure! |
05:07:15, 04 Feb. |
( 227.070000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
05:07:15, 04 Feb. |
( 227.060000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE' |
05:07:15, 04 Feb. |
( 226.440000) NTP synchronization start |
05:07:14, 04 Feb. |
( 225.460000) WAN operating mode is VDSL |
05:07:14, 04 Feb. |
( 225.460000) Last WAN operating mode was VDSL |
05:07:13, 04 Feb. |
( 224.330000) PPP IPCP Receive Configuration ACK |
05:07:13, 04 Feb. |
( 224.300000) PPP IPCP Send Configuration ACK |
05:07:13, 04 Feb. |
( 224.300000) PPP IPCP Receive Configuration Request |
05:07:13, 04 Feb. |
( 224.190000) PPP IPCP Send Configuration Request |
05:07:13, 04 Feb. |
( 224.180000) PPP IPCP Receive Configuration NAK |
05:07:13, 04 Feb. |
( 224.160000) PPP IPCP Send Configuration Request |
05:07:12, 04 Feb. |
( 223.210000) PPPoE is up - Down Rate=40000Kbps, Up Rate=9999Kbps; SNR Margin Down=7.3dB, Up=7.7dB |
05:07:12, 04 Feb. |
( 223.200000) CHAP authentication successful |
05:07:11, 04 Feb. |
( 223.060000) CHAP Receive Challenge |
05:07:11, 04 Feb. |
( 223.060000) Starting CHAP authentication with peer |
05:07:11, 04 Feb. |
( 223.060000) PPP LCP Receive Configuration ACK |
05:07:11, 04 Feb. |
( 223.040000) PPP LCP Send Configuration ACK |
05:07:11, 04 Feb. |
( 223.040000) PPP LCP Send Configuration Request |
05:07:11, 04 Feb. |
( 223.030000) PPP LCP Receive Configuration Request |
05:07:11, 04 Feb. |
( 222.890000) CHAP Receive Challenge |
05:07:11, 04 Feb. |
( 222.890000) Starting CHAP authentication with peer |
05:07:11, 04 Feb. |
( 222.880000) PPP LCP Receive Configuration ACK |
05:07:11, 04 Feb. |
( 222.870000) PPP LCP Send Configuration Request |
05:07:11, 04 Feb. |
( 222.870000) PPP LCP Receive Configuration Reject |
05:07:11, 04 Feb. |
( 222.860000) PPP LCP Send Configuration ACK |
05:07:11, 04 Feb. |
( 222.850000) PPP LCP Receive Configuration Request |
05:07:11, 04 Feb. |
( 222.850000) PPP LCP Send Configuration Request |
05:06:47, 04 Feb. |
( 198.930000) CWMP: session closed due to error: Could not resolve host |
05:06:42, 04 Feb. |
( 193.530000) CWMP: Initializing transaction for event code 4 VALUE CHANGE |
05:06:41, 04 Feb. |
( 192.760000) PPPoE is down after 0 minutes uptime [Disconnected] |
05:06:39, 04 Feb. |
( 190.960000) PPP LCP Send Termination Request [Peer not responding] |
05:06:32, 04 Feb. |
( 183.910000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
05:06:32, 04 Feb. |
( 183.900000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE' |
05:06:02, 04 Feb. |
( 153.580000) CWMP: session closed due to error: Could not resolve host |
05:06:02, 04 Feb. |
( 153.560000) NTP synchronization failure! |
05:05:43, 04 Feb. |
( 134.970000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
05:05:43, 04 Feb. |
( 134.960000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE' |
05:05:43, 04 Feb. |
( 134.340000) NTP synchronization start |
05:05:42, 04 Feb. |
( 133.370000) WAN operating mode is VDSL |
05:05:42, 04 Feb. |
( 133.370000) Last WAN operating mode was VDSL |
05:05:41, 04 Feb. |
( 132.230000) PPP IPCP Receive Configuration ACK |
05:05:41, 04 Feb. |
( 132.200000) PPP IPCP Send Configuration ACK |
05:05:41, 04 Feb. |
( 132.200000) PPP IPCP Receive Configuration Request |
05:05:40, 04 Feb. |
( 132.040000) PPP IPCP Send Configuration Request |
05:05:40, 04 Feb. |
( 132.030000) PPP IPCP Receive Configuration NAK |
05:05:40, 04 Feb. |
( 132.010000) PPP IPCP Send Configuration Request |
05:05:39, 04 Feb. |
( 131.060000) PPPoE is up - Down Rate=40000Kbps, Up Rate=9999Kbps; SNR Margin Down=7.4dB, Up=7.7dB |
05:05:39, 04 Feb. |
( 131.050000) CHAP authentication successful |
05:05:39, 04 Feb. |
( 130.960000) CHAP Receive Challenge |
05:05:39, 04 Feb. |
( 130.960000) Starting CHAP authentication with peer |
05:05:39, 04 Feb. |
( 130.950000) PPP LCP Receive Configuration ACK |
05:05:39, 04 Feb. |
( 130.940000) PPP LCP Send Configuration ACK |
05:05:39, 04 Feb. |
( 130.940000) PPP LCP Send Configuration Request |
05:05:39, 04 Feb. |
( 130.930000) PPP LCP Receive Configuration Request |
05:05:39, 04 Feb. |
( 130.740000) CHAP Receive Challenge |
05:05:39, 04 Feb. |
( 130.740000) Starting CHAP authentication with peer |
05:05:39, 04 Feb. |
( 130.740000) PPP LCP Receive Configuration ACK |
05:05:39, 04 Feb. |
( 130.720000) PPP LCP Send Configuration Request |
05:05:39, 04 Feb. |
( 130.720000) PPP LCP Receive Configuration Reject |
05:05:39, 04 Feb. |
( 130.710000) PPP LCP Send Configuration ACK |
05:05:39, 04 Feb. |
( 130.710000) PPP LCP Receive Configuration Request |
05:05:39, 04 Feb. |
( 130.710000) PPP LCP Send Configuration Request |
05:05:35, 04 Feb. |
ath10: STA 5c:ad:cf:ce:dd:58 IEEE 802.11: Client associated |
05:04:50, 04 Feb. |
( 81.760000) PTM over DSL is up |
05:04:42, 04 Feb. |
( 74.090000) CWMP: session closed due to error: Could not resolve host |
05:04:42, 04 Feb. |
( 74.070000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
05:04:42, 04 Feb. |
( 74.060000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE' |
05:04:33, 04 Feb. |
ath10: STA f0:79:60:74:9e:04 IEEE 802.11: Client associated |
05:04:26, 04 Feb. |
05:04:12, 04 Feb. |
( 43.750000) CWMP: session closed due to error: Could not resolve host |
05:04:11, 04 Feb. |
05:04:07, 04 Feb. |
( 39.080000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
05:04:07, 04 Feb. |
( 39.080000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE' |
05:04:07, 04 Feb. |
( 38.760000) CWMP: Initializing transaction for event code 1 BOOT |
05:04:06, 04 Feb. |
( 37.500000) WiFi auto selected channel 48 |
05:04:06, 04 Feb. |
( 37.500000) 36- 92::40- 92::44- 91::48- 91::52- 90::56- 91::60- 90::64- 90::100- 91::104- 93::108- 93::112- 93::116- 93::120- 95::124- 96::128- 96 |
05:04:06, 04 Feb. |
( 37.500000) 5 GHz Wireless: Rescan, Reason: 'Power- up' |
05:04:06, 04 Feb. |
( 37.500000) WiFi auto selected channel 1 |
05:04:06, 04 Feb. |
( 37.500000) 1- 97::2- 95::3- 96::4- 95::5- 96::6- 97::7- 97::8- 97::9- 99::10- 98::11- 98::12- 98::13- 99 |
05:04:06, 04 Feb. |
( 37.490000) 2.4 GHz Wireless: Rescan, Reason: 'Power- up' |
05:04:05, 04 Feb. |
( 36.870000) WAN Auto- sensing running. |
05:04:01, 04 Feb. |
( 32.450000) System up, firmware version: 4.7.5.1.83.8.263 |
05:03:57, 04 Feb. |
( 28.350000) WPA2 mode selected |
05:03:57, 04 Feb. |
( 28.350000) WPS enabled |
05:03:55, 04 Feb. |
( 26.470000) WPA2 mode selected |
05:03:55, 04 Feb. |
( 26.470000) WPS enabled |
05:03:46, 04 Feb. |
( 17.880000) System start |
04:15:58, 04 Feb. |
ath10: STA 2c:08:8c:00:fd:a5 IEEE 802.11: WiFi registration failed |
04:06:19, 04 Feb. |
ath10: STA 2c:08:8c:00:fd:a5 IEEE 802.11: Client associated |
03:45:58, 04 Feb. |
Re: PPPoE is down after XX minutes uptime/PPP LCP Send Termination Request [User request]
04-02-2019 7:34 PM - edited 04-02-2019 7:34 PM
Sorry to hear you're still having connection issues.
Line tests aren't showing any problems and apart from a drop this morning your connection appears to be stable.
I've attached the test results below:
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 40.0 Mbps |
Upstream Speed | 10.0 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Not Detected |
Estimated Line Length In Metres | 697.2 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Very Good |
Interference Pattern | Regular Interference Observed Daily |
Service Impact | No Impact Observed |
Interference Duration Longest Occurrence | From 17:30 to 20:30 |
Interference Location | Customer Premise |
Interference Observed In Days | 4 |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-40M Downstream, Interleaving Low - 0.128M-10M Upstream, Error Protection Off |
Time Stamp | 2019-02-01T16:00:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 40.0 Mbps | 40.0 Mbps | 40.0 Mbps |
Up Stream Line Rate | 9.9 Mbps | 9.9 Mbps | 9.9 Mbps |
Up Time | 801.0 Sec | 900.0 Sec | 899.1 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2019-02-04T19:09:53Z | 2019-02-04T19:24:53Z |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
I've left your fault ticket open, a faults trained adviser will pick this up over the next few days and if your connection keeps dropping it's likely we'll need to arrange another engineer for further investigation.
04-02-2019 8:17 PM
04-02-2019 8:23 PM
No worries, though to be honest there's not much we can do in the way of a remote investigation for a fibre circuit. Ultimately if the connection continues to drop and line tests don't point to an obvious external fault, the only way we'd be able to progress a fault is by arranging another visit I'm afraid.
05-02-2019 7:57 AM
Anyway let’s see what transpires over the next few days.
05-02-2019 12:40 PM
Hi @Prawnyloks, if you could monitor the connection further that would be great. Checking today I can see the connection is still looking solid with no cause for concern. I appreciate you may not like the idea of another engineer visit if the issue does return however in my several years working faults now I can confirm it could take a few arranged visits for a engineer to locate where the issue is being caused if the problem is looking intermittent like we are seeing with yours. I'm sorry that you were advised the previous engineer visit would be the last and I'll be sure to pass feedback on internally regarding this as your expectations should have been correctly set that we can't guarantee a particular engineer or action taken by a engineer would resolve an issue especially as mentioned given how intermittent this one looks to be. Let us know how it goes over the coming days.
07-04-2019 5:39 PM
It seems that the original issue that prompted me to create this thread has reoccurred. In my initial post here I stated that a "lift and shift" was performed. Other than an odd blip, it seemed that the issue had been fixed. Until this last week it would seem.
Today I noticed a red light on my router, and after looking through the logs, it seems random reboots started reoccurring around a week ago. I now suspect the my "lift and shift" has probably been undone after some other fibre customers has been "fixed".
I have now raised another question stating all the information necessary, but am really hoping for a much quicker resolution than the first time. It took over two months of messing around with unnecessary extra engineer visits, when the simple "lift and shift" fixed things.
I thought I should update this thread to indicate this issue has returned.
08-04-2019 9:20 AM
08-04-2019 1:41 PM
Hi @Prawnyloks, I'm sorry that you are again having issues with your service. Upon testing your line an impairment is being picked up and as the Main Fault Location is being detected as 'at or near to the end user premise', we will need to book an engineer visit to progress this further I'm afraid.
I have updated your fault ticket here, if you could please let us know once you have replied we'll pick it up for you.
08-04-2019 5:50 PM
Hi @LaurenB I have just updated my fault ticket. Thanks for posting here for me to see also.
08-04-2019 6:03 PM
Sorry @LaurenB I forgot to ask can someone do a DLM and profile reset also please. With all the drops in connection my speed has dropped from 40mbps to 31mbps down. Up is still at 10mbps.
08-04-2019 7:20 PM
Hey @Prawnyloks,
Thanks for getting back to us.
I have now booked in your engineer 11/04/2019 PM slot. I have also updated you ticket with the booking info here.
08-04-2019 8:03 PM
I don’t suppose anyone has had chance to reset my DLM yet? If it waits till Thursday I’ll have dropped even more at the rate it’s currently going.
09-04-2019 8:11 AM
I'm afraid there's not much point in requesting a line reset until the engineer goes out as from what we can see the line quality is poor even with the current banding in place.
As a result, it's likely that DLM would band the line and we'd be back to square one. The engineer should put through the reset after fixing the line but if they don't just post here and we'll get that done.
09-04-2019 12:57 PM - edited 09-04-2019 12:59 PM
