PPPOE Dialer Help On Server 2012
mrooks1984
Hi all, has anyone had this working? i have tried on server 2012 by using the connect to internet wizard and filled out my username and password, but it wont connect, do i have to do anything to the ip addressing on the network or does it just work automatically?
i have a network card for internal connections and another one that i want to use for this (which goes directly into the open reach box).
I followed this guide: http://community.plus.net/library/broadband/fibre-help-how-to-set-up-a-pppoe-dialler-in-vistawindows...
Many thanks.
1 REPLY
ian007jen
Re: PPPOE Dialer Help On Server 2012
Try ticking the Internet connection sharing box on the ethernet properties tab.;
Not sure about dhcp and dns are these setup on the server?
Ian
