PPPOE Dialer Help On Server 2012
- PPPOE Dialer Help On Server 2012
12-03-2015 4:26 PM
Hi all, has anyone had this working? i have tried on server 2012 by using the connect to internet wizard and filled out my username and password, but it wont connect, do i have to do anything to the ip addressing on the network or does it just work automatically?
i have a network card for internal connections and another one that i want to use for this (which goes directly into the open reach box).
I followed this guide: http://community.plus.net/library/broadband/fibre-help-how-to-set-up-a-pppoe-dialler-in-vistawindows...
Many thanks.
Many thanks.
Message 1 of 2
(565 Views)
1 REPLY 1
Re: PPPOE Dialer Help On Server 2012
12-03-2015 8:03 PM
Try ticking the Internet connection sharing box on the ethernet properties tab.;
Not sure about dhcp and dns are these setup on the server?
Ian
Ian
Message 2 of 2
(363 Views)
