PPP down since approx 2pm
is there a mass outage on plusnet today, or is this local to me?
modem is still synced with a healthy margin and normal error count.
Fixes: 167
Re: PPP down since approx 2pm
No mass outage. Can you try on your normal username and see if that connects?
There's no obvious issue on the line that I can see, I've run through a test and can see that you're in sync but the PPP just isn't connected.
 Chris Parr
 Plusnet Staff
Already tried Chris, still same.
This is what the router is spitting out.
Jan  1 00:07:05 pppd[706]: Timeout waiting for PADO packets
Jan  1 00:08:20 pppd[706]: Timeout waiting for PADO packets
Jan  1 00:09:35 pppd[706]: Timeout waiting for PADO packets
Jan  1 00:10:50 pppd[706]: Timeout waiting for PADO packets
Jan  1 00:12:05 pppd[706]: Timeout waiting for PADO packets
Jan  1 00:13:20 pppd[706]: Timeout waiting for PADO packets
Jan  1 00:14:35 pppd[706]: Timeout waiting for PADO packets
Jan  1 00:15:50 pppd[706]: Timeout waiting for PADO packets
I will try the normal account again tho, just to be sure.
ok is configured to use my normal account now and I have left it like that so there is no confusion on the fault.
Fixes: 167
We're not actually seeing the connection attempts, even when I test via BT Wholesale. Do you still have the Openreach modem and a router to use with it (just to rule out this being the cause). From what I've seen if this doesn't work you're probably going to need to open a fault ticket.
 Chris Parr
 Plusnet Staff
I am not keen on dropping my sync, but if you say I need to do this before you open the fault I guess I will do it.
ok bear with me as I want to wait 30 mins to resync to keep DLM happy.
Looks like the modem was the issue, it must have partially locked up stopping accepting traffic from the LAN.
Is working again now, thanks.
