PPP down since approx 2pm
- Re: PPP down since approx 2pm
26-05-2015 6:57 PM
is there a mass outage on plusnet today, or is this local to me?
modem is still synced with a healthy margin and normal error count.
Message 1 of 8
(835 Views)
7 REPLIES 7
26-05-2015 7:05 PM
No mass outage. Can you try on your normal username and see if that connects?
There's no obvious issue on the line that I can see, I've run through a test and can see that you're in sync but the PPP just isn't connected.
Message 2 of 8
(529 Views)
26-05-2015 7:06 PM
Already tried Chris, still same.
This is what the router is spitting out.
Jan 1 00:07:05 pppd[706]: Timeout waiting for PADO packets
Jan 1 00:08:20 pppd[706]: Timeout waiting for PADO packets
Jan 1 00:09:35 pppd[706]: Timeout waiting for PADO packets
Jan 1 00:10:50 pppd[706]: Timeout waiting for PADO packets
Jan 1 00:12:05 pppd[706]: Timeout waiting for PADO packets
Jan 1 00:13:20 pppd[706]: Timeout waiting for PADO packets
Jan 1 00:14:35 pppd[706]: Timeout waiting for PADO packets
Jan 1 00:15:50 pppd[706]: Timeout waiting for PADO packets
I will try the normal account again tho, just to be sure.
Message 3 of 8
(529 Views)
26-05-2015 7:12 PM
ok is configured to use my normal account now and I have left it like that so there is no confusion on the fault.
Message 4 of 8
(529 Views)
26-05-2015 7:26 PM
We're not actually seeing the connection attempts, even when I test via BT Wholesale. Do you still have the Openreach modem and a router to use with it (just to rule out this being the cause). From what I've seen if this doesn't work you're probably going to need to open a fault ticket.
Message 5 of 8
(529 Views)
26-05-2015 7:34 PM
I am not keen on dropping my sync, but if you say I need to do this before you open the fault I guess I will do it.
Message 6 of 8
(529 Views)
26-05-2015 7:48 PM
ok bear with me as I want to wait 30 mins to resync to keep DLM happy.
Message 7 of 8
(529 Views)
26-05-2015 8:24 PM
Looks like the modem was the issue, it must have partially locked up stopping accepting traffic from the LAN.
Is working again now, thanks.
Message 8 of 8
(529 Views)
