PPP authentication fault
Fixes: 61
Could this be down to being moved to the new network given that the connection to the cab is solid but can't connect to the internet after trying all the usual tests including changing router and connecting directly to the BT Modem
If not what are the likely causes - note this isn't my connection
Fixes: 61
Re: PPP authentication fault
Update
Can now access Plusnet sites but no others - could this be the new network transfer screwing things up
Fixes: 30
Have you changed password on the member site by any chance? Or has the router lost it's password?
Fixes: 61
nothing to do with that - all checked as part of the fault reporting
now that the Plusnet site can be accessed it was possible to login to the member centre and add a note to the fault ticket
CJC1942
Hi Jim,
Can't even access Plusnet now!!
Ces
Fixes: 61
Good job you can piggyback on my connection then
CJC1942
It's much appreciated, what's your favourite tipple?
Since the backward step I have repeated changing routers exercise with no improvement.
Fixes: 61
Just so long as you let me do the same when mine goes down again Thumbs Up
All I need to do now is to find out how to set up one of my routers as a wireless repeater and invest in a wifi dongle for my Win 7 PC - or am I just being too pessimistic
Isn't it about time for the 72 hours for the fault report running out
CJC1942
That goes without saying!
It could depend on the definitions of  "72 hours" and the "start time" of those 72 hours!
