PPP authentication fault
- Re: PPP authentication fault
15-09-2016 10:37 AM - edited 15-09-2016 10:38 AM
Could this be down to being moved to the new network given that the connection to the cab is solid but can't connect to the internet after trying all the usual tests including changing router and connecting directly to the BT Modem
If not what are the likely causes - note this isn't my connection
15-09-2016 11:54 AM
Update
Can now access Plusnet sites but no others - could this be the new network transfer screwing things up
15-09-2016 12:11 PM - edited 15-09-2016 12:11 PM
Have you changed password on the member site by any chance? Or has the router lost it's password?
15-09-2016 12:21 PM
nothing to do with that - all checked as part of the fault reporting
now that the Plusnet site can be accessed it was possible to login to the member centre and add a note to the fault ticket
16-09-2016 2:51 PM
Hi Jim,
Can't even access Plusnet now!!
Ces
16-09-2016 3:00 PM
Good job you can piggyback on my connection then
16-09-2016 3:13 PM
It's much appreciated, what's your favourite tipple?
Since the backward step I have repeated changing routers exercise with no improvement.
16-09-2016 3:50 PM - edited 16-09-2016 3:51 PM
Just so long as you let me do the same when mine goes down again
All I need to do now is to find out how to set up one of my routers as a wireless repeater and invest in a wifi dongle for my Win 7 PC - or am I just being too pessimistic
Isn't it about time for the 72 hours for the fault report running out
16-09-2016 3:56 PM
That goes without saying!
It could depend on the definitions of "72 hours" and the "start time" of those 72 hours!
