PN line speed stuck
smithcomputers
PN line speed stuck
Good Morning, Please could someone give my line speed a nudge as it is stuck at 5.9m. We had a fault which was fixed a few weeks ago and we are back up to 6.67 on the BT tester but your side has not increased. Now I know its not a lot some will say but when your fibre only reaches approx 7m then any drop makes a difference and losing nearly a meg in speed does make a diff when 2 or 3 are using the connection. Any help would be very much appreciated and I must also thank you for getting the line fault fixed so quickly, Thank you in advance.
Mike..
Plusnet Staff
Plusnet Staff
Fixes: 115
Re: PN line speed stuck
I've tested your line and I can see your router is in sync at 6.9 Mbps which indicates that the speed profile is correct.
Circuit Sync Status
: In Sync
Downstream Line Rate
: 6.9
Upstream Line Rate
: 1.1
I've nudged the profile up to 6.9 for you now but it's likely to drop down automatically.
I've joined the Plusnet Help Team as of May 2017. As such, I have a new forum account. Please direct any queries to @Gandalf. Thanks
 Plusnet Support
smithcomputers
Thank you v much that is much appreciated.
Cheers
          Mike..
Plusnet Staff
Plusnet Staff
Fixes: 115
No problems, if there's anything else I can help with please let me know. Smiley
 Plusnet Support
