PN line speed stuck
smithcomputers
PN line speed stuck
Good Morning, Please could someone give my line speed a nudge as it is stuck at 5.9m. We had a fault which was fixed a few weeks ago and we are back up to 6.67 on the BT tester but your side has not increased. Now I know its not a lot some will say but when your fibre only reaches approx 7m then any drop makes a difference and losing nearly a meg in speed does make a diff when 2 or 3 are using the connection. Any help would be very much appreciated and I must also thank you for getting the line fault fixed so quickly, Thank you in advance.
Mike..
3 REPLIES 3
Anoush
Plusnet Staff
Plusnet Staff
Fixes: 126
Re: PN line speed stuck
I've tested your line and I can see your router is in sync at 6.9 Mbps which indicates that the speed profile is correct.
Circuit Sync Status
: In Sync
Downstream Line Rate
: 6.9
Upstream Line Rate
: 1.1
I've nudged the profile up to 6.9 for you now but it's likely to drop down automatically.
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
smithcomputers
Thank you v much that is much appreciated.
Cheers
          Mike..
Anoush
Plusnet Staff
Plusnet Staff
Fixes: 126
No problems, if there's anything else I can help with please let me know. Smiley
