PN Router
Fixes: 8
PN Router
Can someone confirm what router is currently supplied by PN for new fibre customers.
The package deals show a wireless router value £40 will be supplied free excluding P&P.
I understood PN are now supplying BT routers, is this correct ? if not are there plans to do so and what model of BT router would be supplied ?
Fixes: 29
Re: PN Router
Its a PN badged Hub One which is based on a BT HH5A.
Browni
Seasoned Champion
Fixes: 36
Re: PN Router
Currently they are supplying a Plusnet Hub One which is a rebranded BT Homehub 5a
It's good points are dual band wireless AC1600 & 4 Gigabit ethernet ports.
I must have been really bad in a previous life. This is my 3rd ISP in a row that uses lithium.
Fixes: 8
Re: PN Router
Thanks for the replies.
Smiley
