PN Profile speed uplift
VinceMarsters
My router resynced yesterday from 69000 to 79900. How long before the PN profile speed gets an uplift too - https://portal.plus.net/my.html?action=data_transfer_speed is still showing 66.6Mb? I thought it used to be within a few hours of the resync and line stability. I have tried running BTW speed tests but these keep failing at the diagnostic section in Edge and FF (and I don't really like running flash, given it is now on life support with Adobe).
Fixes: 20
Re: PN Profile speed uplift
Hi @VinceMarsters
Looks like your profile is back to >80M D/S Smiley
Test Outcome - Pass
Test Outcome Code - GTC_FTTC_SERVICE_0000
Description - GEA service test completed and no fault found .
Main Fault Location - OK
Sync Status - In Sync
Downstream Speed - 79.9 Mbps
Upstream Speed - 20.0 Mbps
Appointment Required - N
Fault Report Advised - N
NTE Power Status - Power On
Voice Line Test Result - Pass
Bridge Tap - Not Detected
Radio Frequency Ingress - Not Detected
Repetitive Electrical Impulse Noise - Not Detected
Cross Talk - Not Detected
Estimated Line Length In Metres - 214.9
Upstream Rate Assessment - Very Good
Downstream Rate Assessment - Very Good
Home Wiring Problem - Not Detected
Downstream Policing Discard Rate - 0.0
Customer Traffic Level - Upstream and Downstream Traffic  Detected
Technology - VDSL
Profile Name - 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off
Let us know if there is anything we can do going forward for you.
 Alisdair C
VinceMarsters
Thank you. The profile shown in my account is showing the uplift too now.
