PLA Speed loss
- Re: PLA Speed loss
PLA Speed loss
29-08-2015 2:49 PM
For the last 3 years I have always used PLA wired to my laptop. I've been on fibre 40/20 since January and my download via wired PLA had always been around the 28-29Mb download 17Mb upload.
However since the Sagemcon router/PN TV I am struggling to get speeds above 13MB via the PLA wired and wifi, even with the ethernet disconnected from the You View box [Viewing via You View is fine and no buffering] my upload is faster than the download! Nothing [that I am aware of] has changed but the router.
I've tried using my old PLA that I had the better speeds with but it has decreased via those as well the only thing I haven't done is try the Technicolor TG582 again.
I can't see there is a connection with the new router and know PN will say they can't help as the wired speed straight to the router is acceptable but wondered if any one has any ideas?
Re: PLA Speed loss
31-08-2015 1:08 PM
Re: PLA Speed loss
31-08-2015 2:02 PM
Side by side the speed reads 34Mb so I guess it's down to the house wiring? I have no idea why it has dropped so drastically.
Edit: I've just unplugged the You View box and the speed has gone back up again.
Re: PLA Speed loss
06-09-2015 7:11 AM
After trial and error I unplugged the YV Box from an extension lead and plugged it straight into the wall socket and my speeds have gone back to what they were via the PLA.
Fingers crossed it stays that way.
Re: PLA Speed loss
06-09-2015 8:31 AM
That's my arrangement and I suspect it may be emmitting noise
To be is to do - Kant
do be do be do - Sinatra
Re: PLA Speed loss
06-09-2015 9:29 AM
Re: PLA Speed loss
06-09-2015 9:53 AM
Re: PLA Speed loss
06-09-2015 10:06 AM
Re: PLA Speed loss
07-09-2015 7:22 AM
Re: PLA Speed loss
07-09-2015 7:42 AM
Re: PLA Speed loss
07-09-2015 8:04 AM
