Hello
For the last couple of days I have been unable to play Counter Strike or login to Steam (it's definitely up). I think it is due to 'something weird' happening to my UDP traffic. I start "Steam.exe -tcp" to use only TCP and login to Steam works fine, however playing the game online never works, as I assume UDP is required in-game.
There's been no change to my router, running Wireshark on a laptop with Steam and Counter Strike running in UDP mode shows absolutely no UDP traffic coming back to the laptop from the Internet.
Any ideas?
Many thanks
