Outage in Newtown Powys
- Outage in Newtown Powys
04-02-2022 7:36 AM
Re: Outage in Newtown Powys
04-02-2022 7:39 AM
@shazzbot Which Hub are you using, and what is the colour of the lights?
04-02-2022 7:40 AM
04-02-2022 7:47 AM - edited 04-02-2022 7:48 AM
OK , so the router is still connected to the internet according to that. What happens if you try to connect with a site?
When did you get a (PN?) Hub2?
04-02-2022 7:50 AM
Bought the hub 2 from EBay a couple of months ago.
04-02-2022 7:55 AM
Ah, OK, so it is an ex-BT one - strange because I thought BT now charged you if you didn't return them, but no matter.
What is the 'username' showing on the Hub? It is possible this has been returned to 'setup'?
04-02-2022 7:59 AM
04-02-2022 8:02 AM
OK - in that case, you need to reset it to 'yourusername@plusdsl.net' and your account password - it will never work correctly with that username.
04-02-2022 8:06 AM
04-02-2022 8:08 AM
Glad you sorted it. I'm no 'genius' - just someone who knows what can go wrong with the 'net.
04-02-2022 3:14 PM
