Ordered Plusnet Fibre - Now not enabled at exchange?
- Ordered Plusnet Fibre - Now not enabled at exchang...
03-11-2015 10:21 AM
Hi all!
My order went through fine, but I've just received this message in the Support bit of the member center:
Now, the exchange is definitely FTTC enabled (https://www.samknows.com/broadband/exchange/THDK)
And the BT Wholesale checker says the cabinet is FTTC (range A & B) enabled: https://i.imgur.com/VosK0Lp.png
Does this mean Plusnet doesn't have LLU equipment in the exchange? Otherwise, what's going on here?
Thanks!
Quote [INTERNAL]
Fibre isn't available at this exchange. Please contact the customer to arrange an alternative product.
Thanks!
Message 1 of 4
(710 Views)
3 REPLIES 3
Re: Ordered Plusnet Fibre - Now not enabled at exchange?
03-11-2015 10:28 AM
The line is definitely showing as available for fibre.
We don't have LLU equipment in any exchange, we use BT Wholesale lines.
Is your line a conversion from an LLU provider (Sky etc) as it's likely that when the order was placed the line records hadn't updated.
Leave it with me and we'll get your order placed asap.
Quote Does this mean Plusnet doesn't have LLU equipment in the exchange?
Message 2 of 4
(451 Views)
03-11-2015 10:39 AM
Yes, the property used to be supplied by Sky.
Thank you for the quick reply, I'll await further updates!
Message 3 of 4
(451 Views)
03-11-2015 2:56 PM
I'm just sorting the order now and will confirm that to you on your account shortly.
Message 4 of 4
(451 Views)
