Orange light
- Re: Orange light
Orange light
03-06-2020 5:20 PM
I’ve got to say I’m disappointed in this service, first I had a fault for slow speeds which eventually got sorted and now this.
Re: Orange light
04-06-2020 5:06 PM
Hello @Crowen_2007
Thanks for getting in touch with us here. I'm sorry to read you've had some trouble with your connection and I apologise for the disruption caused. On testing the connection a fault has been detected so we'll need to go ahead an go through some troubleshooting steps first. If they don't help alleviate he issue we'll need to go ahead with an engineer appointment to the premises.
Please can you run through our troubleshooting guides here If that doesn't help, the next thing would be to rule your internal wiring out by plugging the connection into your test socket (which is under the faceplate of your master socket) and seeing if the drops stop. This rules out your internal wiring, face plates and extension sockets as being the cause of these drops.
How to locate the test socket and set your connection into it can be found here
If the problem still persists, please can you raise a fault here and let us know once this has been done?
Thanks.
Re: Orange light
04-06-2020 5:12 PM
Re: Orange light
04-06-2020 5:25 PM
Re: Orange light
04-06-2020 5:36 PM
I’ve watched the video and my setup is already what it tells you to do in the video so I shall I just go straight to putting it in the test socket?
