Orange light with broadband light flashing red
slwukuk77
HelpHuhHuh
bluewhale
Re: Orange light with broadband light flashing red
log onto the router page and have a look at the event log, in particular the WAN bit
also you may want to do a quiet line test ie call 17070 see if noise on line
you might also want to try using the test socket on the BT faceplate
https://www.plus.net/help/broadband/connection-troubleshooting/
slwukuk77
Found out that my internet isn't even live yet, after being informed by plusnet that it was. Should be active in a couple of days, fingers crossed.....again
Fixes: 541
Sorry to hear you can't connect.
Can you let us know how you get on once your broadband service is live?
