Orange light with broadband light flashing red
- Re: Orange light with broadband light flashing red
05-12-2017 10:09 AM
Help??????
Message 1 of 4
(4,047 Views)
3 REPLIES 3
05-12-2017 11:38 AM
log onto the router page and have a look at the event log, in particular the WAN bit
also you may want to do a quiet line test ie call 17070 see if noise on line
you might also want to try using the test socket on the BT faceplate
https://www.plus.net/help/broadband/connection-troubleshooting/
Message 2 of 4
(4,023 Views)
05-12-2017 12:12 PM
Found out that my internet isn't even live yet, after being informed by plusnet that it was. Should be active in a couple of days, fingers crossed.....again
Message 3 of 4
(4,009 Views)
05-12-2017 12:33 PM
Message 4 of 4
(3,998 Views)
