Orange light and flashing red B on router
nm43
Browser
My router has been like this for a couple of hours now. No internet and the light on my router is orange with this red b symbol underneath. Resetting it makes no difference it just goes back to the same orange light and the red b. I've got a dial tone on the phone, no issue there. We moved home and transferred to this address a week ago, has been working okay until now. Help!
2 REPLIES 2
Thrall
Seasoned Pro
Fixes: 23
Re: Orange light and flashing red B on router
Try plugging your router into the test socket: https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
Failing that it’d be worth raising a fault ticket at faults.plus.net so an agent can investigate
nm43
Browser
Thank you! I've tried that and issue is still the same. Will raise a fault ticket.
