turn on suggestions
Openreach modem
- Openreach modem
Openreach modem
Openreach modem
18-03-2016 11:23 AM
I've recently changed from Bt to Plusnet and was using the bt hub 4 in conjunction with an Openreach modem. Do I still need to use the modem with the Plusnet router?
Re: Openreach modem
Re: Openreach modem
18-03-2016 11:26 AM
If you've been sent the Hub one, answer is no
Just plug phone into the hub one and away you go
Raspberry Pi enthusiast!
If you Like it, give it a
Re: Openreach modem
Re: Openreach modem
18-03-2016 11:31 AM
Thank you! I'll give it a go
