Openreach can't remove kci3
FIXED- Subscribe to RSS Feed
- Openreach can't remove kci3
31-07-2017 12:25 PM
Fixed! Go to the fix.
Re: Openreach can't remove kci3
31-07-2017 8:02 PM
As per our conversation over Facebook, I'm not sure why we'll need to install a new line. The stuck order relates to the broadband side of things. Do you have dial tone on your home phone handset?
on 31-07-2017 8:07 PM - last edited on 31-07-2017 9:17 PM by Strat
Yep I have dial tone I'm only going by what I was told today by your staff called [CSA Removed]
Paul.
Moderator's note by Dick (Strat) CSA name/s removed to private staff area as per Forum rules
01-08-2017 4:55 PM
01-08-2017 5:07 PM
Happy to hear that! Once the stuck order progresses, it's likely to cease your fibre service because it's a cease order. But once that happens we'll be able to replace the fibre order for you.
01-08-2017 5:23 PM
01-08-2017 5:27 PM
@shrubb2121 wrote:
Openreach can't remove kci3 off my line plusnet now saying only way around this having a new line installed with a brand new phone number so fed up as my fibre broadband stopped working on 19th July because of this kci3 error.
I've had a look over the notes on the cancelled cease order that has become stuck on our suppliers systems and it looks like they've advised that the cease did complete (Which would explain the loss of service) however because no KCI3 (Basically the order completion notification) was sent through, the order still shows as open and searching the asset still returns an active asset.
As there is an open cease order on the systems (Despite this actually being complete) we can't begin to re-provide the service due to an open order on an active asset, whereas we need to be able to place an order on a clear line (No asset).
This has been chased up several times with our suppliers and they are working on resolving this issue so we can take the appropriate action to re-provide the service.
The order is stuck due to an exception, however a bridge case has been raised to resolve this and this has also been escalated with the appropriate team with our suppliers.
We've been asked to check back tomorrow for an update.
Thank you for your patience, I do sincerely apologise for any inconvenience this is causing.
Exception: These are system related issues that stop an order from progressing. There are a variety of reasons for these
Bridge Case: These are raised to both Openreach and BT Wholesale to resolve system related problems with orders.
01-08-2017 5:42 PM
You are already providing the service I said in my last post BT openreach visited me today my fibre connection was pulled out from green cabinet box which has now been re connected i now have fibre connection.
01-08-2017 5:49 PM
01-08-2017 5:54 PM
01-08-2017 6:04 PM
Whilst that's partly true, the order on our suppliers system is essential for your router to authenticate [and in some cases, even sync to the cabinet].
If the cease order completes, we'd have to place a provide order and we will try our very best to get it fast tracked however at this point I can't make any guarantees.
02-08-2017 5:00 PM
Looks like your supplies has completed stuck cease order as my fibre connection has gone off what happens now.
Paul
02-08-2017 7:51 PM
03-08-2017 11:42 AM
Paul.
03-08-2017 6:30 PM
