Openreach appears to be taking lower noise margin trial national
Browni
Seasoned Champion
Fixes: 36
From thinkbroadband.com
A trial has been running looking into whether Openreach can squeeze more speed out of VDSL2 for some lines with no hardware changes in the cabinet or by the customers VDSL2 modem and it seems on Monday 20th March, this limited area trial is set to go national.
Full story
I must have been really bad in a previous life. This is my 3rd ISP in a row that uses lithium.
Re: Openreach appears to be taking lower noise margin trial national
My downstream SNR margin started falling a few weeks ago, and is currently sitting at 2.0 dB. Since this started happening the line has remained very stable (current DSL up-time is 21 days 7 hours and some minutes/seconds).
I've gained around 10Mb/sec downstream since this started, so I presume I've been part of the trial.
jamesanstee
I was on the trial at the beginning of march then got took off but now back on it again with the 3db profile .
MikeBz
So is it only on the downstream?  SadSadSad
Certainly no change on my upstream.
Champnet
Midday yesterday the Router re-booted, the downstream SNR dropped from 6 to 3db and it gained around 10Mb/sec downstream. Shortly afterwards I had to make system changes to the Router which re-booted itself. SNR and downstream speed reverted to what it was previously
Anyone think the DLM will try again or is that it ?
Kevin
Looks like my cabinet is now in the trial as in the ;last 3 weeks DLM has lowered my snrm to 3dB (goes up to 4.8 sometimes.
HH5 Type B says...
5. VDSL uptime: 0 days, 04:38:09
6. Data Rate: 20000 / 79237
7. Maximum Data Rate: 32217 / 79820
8. Noise Margin: 13.9 / 3.1
9. Line Attenuation: 15.7 / 14.5
And BT test shows...
1. Best Effort Test:  -provides background information.
  Download Speed
  63 Mbps
0 Mbps 72.89 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 63 Mbps
 For your connection, the acceptable range of speedsis 40 Mbps-72.89 Mbps .
 Additional Information:
 IP Profile for your line is - 72.89 Mbps
2. Upstream Test:  -provides background information.
  Upload Speed
  17.34 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 17.34Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
But Plusnet speed is resolutely set at 66Mb
Shouldn't the Plusnet speed automatically follow the BT one?
If not can a nice person nudge my speed up please.  Smiley
Kevin.
kevinduke
Same thing here.
Just gone through the process to reduce my snr to 3 dB,  BT profile at 77.35 but Plusnet stuck at 71.8
Max: Upstream rate = 23782 Kbps, Downstream rate = 82304 Kbps
Bearer: 0, Upstream rate = 19999 Kbps, Downstream rate = 79999 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Down Up
SNR (dB): 3.6 15.1
Attn(dB): 17.3 0.0
Pwr(dBm): 14.0 7.3
The current Downstream BRAS rate is: 77.35 Mbps
The current Upstream BRAS rate is: 20 Mbps
Been stable for 12 days now so could do with a nudge plus net's end.
Kevin
Fixes: 57
my experience is that the Plusnet profile is very iffy on upgrading and has been for years
brookheather
I've yet to see the Plusnet line speed go up automatically with increased sync speed yet it seems to drop down within days when the sync speed drops.  I've had to request a manual increase twice this year after my line speed was capped following a fault and a new router that required some tweaking to increase the sync rate.  Your current line speed can be checked here:
Fixes: 227
@Kevin and @kevinduke
I've just given your profiles a nudge.
Can you perform a single disconnect/reconnect and let us know how your throughput looks?
kevinduke
Hi @Gandalf
Thank you for that
Download speed
achieved during the test was - 73.27 Mbps
is 40 Mbps-77.35 Mbps .
 IP Profile for your line is - 77.35 Mbps
Kevin
Fixes: 227
No problems Kevin
Let us know if there's anything else we can assist with.
Kevin
Download speed achieved during the test was - 72.51 Mbps
For your connection, the acceptable range of speeds is 40 Mbps-72.89 Mbps .
Looking good!!  Smiley
Thanks @Gandalf Thumbs Up
Kevin.
