Opening Ports
- Opening Ports
Opening Ports
03-06-2017 1:19 PM - edited 03-06-2017 1:25 PM
Hi, i am using a netgear D6220 router. I am trying to open ports 3074 and 28690 in order to play cod WaW. I have added these ports to port forwarding in router settings and in windows 10 firewall. But no luck, still closed/ blocked.
A friend mentioned that my it looks like my ip is being forwarded through some kind of dns? I am not entirely sure what that all means. Plusnet have said they don't forward through any kind of dns but its strange that that's what it looks like. They also said they don't block any ports but that i should ask on the forums for help!
Any help is appreciated, Thanks.
UPDATE: after talking to Plusnet, when i type in, My ip, to google it now comes up with a different address, it used to be along the lines of 192.168.... but now starts with 51.9.... I used to have to type in the 192... to get in to router settings but now i have to type in the 51.9... address.
Re: Opening Ports
03-06-2017 1:44 PM
Check that your PlusNet Firewall is Off https://portal.plus.net/my.html?action=firewall&firewallPage=basic (login required) although I thought these days it defaulted to Off. If you have to change it then you will need to disconnect & reconnect your PPPoE session for it to take effect.
Re: Opening Ports
03-06-2017 1:48 PM
Plusnet Firewall is off!
Re: Opening Ports
03-06-2017 2:25 PM
Re: Opening Ports
03-06-2017 2:43 PM
I just used to always connect via the private ip, but it no longer connects to my router. I am definitely connected to my router! I didnt disconnect or anything after talking to plusnet, and since talking to them it hasnt worked. All they said was that they could not help though? didnt think they'd done anything to change any settings!
Re: Opening Ports
03-06-2017 3:04 PM
I'd be pretty sure that PN haven't changed any settings. However I'd first suggest rebooting both the router and the PC. If that doesn't fix it then (assuming you're running Windows on the PC ) :-
from a command prompt run ipconfig /all and see what comes up as the default gateway.
Re: Opening Ports
03-06-2017 8:29 PM
Restarted router and computer. When i check my ip through google it has now changed again to something along the lines of 37.152....
I ran the cmd, and my default gateway is now 192... however the last number has changed from what it was this morning. But i can log in to the router with it now. My main problem is still opening the ports?
Re: Opening Ports
04-06-2017 9:40 AM
I'm not familiar with the D6220 but looking at the manual ( port forwarding page 238 ) it looks pretty straightforward. Have you assigned a reserved IP address ( page 184 ) to your PC first before configuring the port forwarding ?
Re: Opening Ports
04-06-2017 10:57 AM
I have added my computer to a reserved ip, the one its currently on 192.168.0.2
This has not helped either, when i run a scan of the common ports all of them come up as filtered? is that to be expected? Really can'y figure out why, after adding them in router settings and windows 10 firewall they still aren't open.. Thanks for the help/suggestions so far.
Re: Opening Ports
04-06-2017 11:10 AM
Have you tried removing the port forwading and letting UPnP sort it out. Make sure that UPnP is enabled on the router as here https://kb.netgear.com/24306/How-do-I-enable-Universal-Plug-and-Play-on-my-Nighthawk-router ( assuming it's similar for your router )
Re: Opening Ports
04-06-2017 12:23 PM
UPnP was already turned on? should i leave that on or try turning it off?
Re: Opening Ports
04-06-2017 1:02 PM
I'd try the various combinations:-
UPnP - off - port forwarding - on
UPnP - on - portforwarding - on ( already tried ? )
UPnP - on - portforwarding -off
UPnP - off - portforwarding - off ( that's probably not going to work at all ! )
If that doesn't help then I suspect we're going to have to see if someone with more experience of WaW comes along...
Re: Opening Ports
04-06-2017 2:00 PM
with UPNP turned on it should just work - COD I would also make any adjustments it needs to get through the Windows Firewall....
Have you confirmed that the PC is using the address that you've sent up the forwarding to?
Re: Opening Ports
04-06-2017 2:31 PM
@SteveA, that's the whole point of UPnP you don't need to do any manual adjustments.
Re: Opening Ports
04-06-2017 2:41 PM
@Anonymous .. I know, which is why I'm surprised that discussing opening ports to just play a game is even happening
