Open Reach caps speed until restart
adam1240
Hello, i been having issues after every 24 or so hours my open reach caps my speed to 10 download, and 10 Upload (getting average 9.87 DL/UPload)
Until i go and turn it off for 30 seconds and put it back on then i reach my speeds, 30+MB Download / 15+ Upload.
i used to have internet cut out's but since i brought my new router that's not an issue.
Can anyone help?
Fixes: 162
Re: Open Reach caps speed until restart
Did you get the same speed issues on the previous router?
Are you still using the openreach modem or does the new router not need that?
 Chris Parr
 Plusnet Staff
adam1240
my router is This : TP link TL-WDR 3600
It requires a modem too, so open reach one supplied by plus net.
i believe it did yes, but the router you supplied kept disconnecting my internet this one does not.
