Open Reach caps speed until restart
- Re: Open Reach caps speed until restart
23-01-2015 12:29 PM
Hello, i been having issues after every 24 or so hours my open reach caps my speed to 10 download, and 10 Upload (getting average 9.87 DL/UPload)
Until i go and turn it off for 30 seconds and put it back on then i reach my speeds, 30+MB Download / 15+ Upload.
i used to have internet cut out's but since i brought my new router that's not an issue.
Can anyone help?
Can anyone help?
Message 1 of 3
(595 Views)
2 REPLIES 2
23-01-2015 12:34 PM
Did you get the same speed issues on the previous router?
Are you still using the openreach modem or does the new router not need that?
Message 2 of 3
(254 Views)
23-01-2015 1:52 PM
my router is This : TP link TL-WDR 3600
It requires a modem too, so open reach one supplied by plus net.
i believe it did yes, but the router you supplied kept disconnecting my internet this one does not.
Message 3 of 3
(254 Views)
