Open Ports when scanned externally
- Open Ports when scanned externally
05-10-2017 3:04 PM
Curious as to why when I scan my external ip address with nmap (externally to my home network) all the ports come back as open? Whats the reasoning for this?
I know they aren't all open as I run a pfsense firewall instead of the plusnet supplied modem.
Re: Open Ports when scanned externally
05-10-2017 4:48 PM - edited 05-10-2017 4:50 PM
Try running Shields Up from Gibson Research (grc.com) from inside your network and see what they say.
09-10-2017 9:11 AM
This is just a glorified nmap scan so won't make any difference?
I have scanned from multiple external internet connections and the result is the same - can anyone from plusnet clarify why this is?
09-10-2017 9:23 AM
We don't block any ports out on our network unless you have our server side firewall enabled.
09-10-2017 9:27 AM - edited 09-10-2017 9:28 AM
I am using a BT Openreach modem (white box) provided by plusnet that feeds in to a dedicated pfsense router. All ports closed bar a select few.
As far as i know not using the plus net firewall
