Only getting half speed on an upto 36mbps Unlimited Fibre connection
cszombie
I've just switched but i'm seeing only half the speed i'm supposed to get, i know there's 10 days for things to settle down but i'm sure it should already be faster than this?
Here's what i'm getting...
Estimated line speed:40Mb (This may vary between 30.8Mb and 40Mb) - Checked on 2017-03-23 13:34:57Current line speed:18.7 Mb
..is anybody able to assist with a solution please?
Fixes: 37
Re: Only getting half speed on an upto 36mbps Unlimited Fibre connection
If you've just switch over to fibre then I suspect that your profile is needing to be reset from ADSL speeds can you do a speed test using this then select the 'Further Diagnostics" option at the bottom of the results page. This will tell you your profile when complete and make the results available to Plusnet.
Plusnet Staff
Plusnet Staff
Fixes: 117
Hi @cszombie I am sorry to hear you are having speed problems. I've tested your line and I've identified a possible external fault. I've raised this with our faults team and our suppliers now. We expect an update within the next 72 hours.
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
cszombie
Thank you, an engineer has been from BT Openreach today, replaced master socket faceplate and line outside property, getting speeds now of 31mb download, live chat customer support also changed profile on the line, i think it must have been still on adsl speeds as mook suggested, happy! Thanks again Smiley
Plusnet Staff
Plusnet Staff
Fixes: 117
Fantastic news, thanks for getting back to us. That was fast, the engineer went out about an hour after I raised it.
Happy to hear your speeds are up. Smiley
 Plusnet Staff
