Online gaming just hasn't been right for a long time now.
FrazUK
For about 2 years now there has been something just not right with online multiplayer gaming. Even though I always have a stable ping, no packet loss, and generally good all round connection stats. Everything should be fine, but it's not.
All online games I play seem to suffer from the same oddities, variable delay in hit registration/responsiveness, terrible hit reg in general, out of sync player positioning/seeing things very differently compared to other players, jittery movement on other players, players warping out of nowhere or warping back from where they are and the feeling that other players have a huge advantage since it feels like I'm always 1 second behind everyone else/I'm seeing things late on my end.
Here's a thread on Reddit from someone else in England(nor sure of ISP yet) about CS: GO of someone explaining the exact same problems (keep in mind this isn't just a CS: GO problem for me)
This happens across all games, over 3 PCs, a laptop and Xbox One(All connected over ethernet) in 2 properties (next door to each other), next door on BT Infinity and mine on Plusnet. It's much easier to see in CS: GO due to how the game works, you can really tell when something is delayed. In other games, it's not so obvious outside of gameplay just not feeling right, but the problems are there.
I don't know if it's a routing problem or what, but it doesn't make sense to have a stable connection but see all of these problems. As I said this has been going on for at least 2 years now and it's about time it was sorted. I've come across quite a few people with the same problems with the majority of them being from the UK.
Cheers!
Moderator's note by Mike (Mav): Post released from Spam Filter.
1 REPLY
FrazUK
Re: Online gaming just hasn't been right for a long time now.
Looks like Telia is still messed up. You can see the massive variation when the Telia network is hit...
Tracing route to 91.108.183.19 over a maximum of 30 hops
  1    <1 ms    <1 ms    <1 ms  LEDE.lan [192.168.1.1]
  2     *        *        *     Request timed out.
  3    22 ms    21 ms    21 ms  133.hiper04.sheff.dial.plus.net.uk [195.166.143.133]
  4    21 ms    22 ms    21 ms  be3-3102.pcn-ir02.plus.net [195.166.143.132]
  5    23 ms    22 ms    23 ms  195.99.125.140
  6    22 ms    22 ms    22 ms  core3-hu0-14-0-7.faraday.ukcore.bt.net [195.99.127.64]
  7    22 ms    21 ms    22 ms  213.137.183.36
  8    22 ms    23 ms    22 ms  ldn-b3-link.telia.net [213.248.67.97]
  9    22 ms    31 ms    22 ms  ldn-bb3-link.telia.net [62.115.117.12]
 10    55 ms    35 ms    37 ms  hbg-bb1-link.telia.net [62.115.122.164]
 11    54 ms    55 ms    52 ms  s-bb3-link.telia.net [62.115.142.138]
 12    49 ms    49 ms    49 ms  s-b5-link.telia.net [62.115.137.159]
 13    48 ms    48 ms    49 ms  netirons-ic-316918-s-b5.c.telia.net [62.115.145.255]
 14    49 ms    48 ms    49 ms  5.157.4.11
 15    49 ms    50 ms    50 ms  91.108.183.19
Trace complete.
ping 62.115.122.164 -n 100
Pinging 62.115.122.164 with 32 bytes of data:
Reply from 62.115.122.164: bytes=32 time=62ms TTL=55
Reply from 62.115.122.164: bytes=32 time=74ms TTL=55
Reply from 62.115.122.164: bytes=32 time=36ms TTL=55
Reply from 62.115.122.164: bytes=32 time=163ms TTL=55
Reply from 62.115.122.164: bytes=32 time=35ms TTL=55
Reply from 62.115.122.164: bytes=32 time=60ms TTL=55
Reply from 62.115.122.164: bytes=32 time=104ms TTL=55
Reply from 62.115.122.164: bytes=32 time=72ms TTL=55
Reply from 62.115.122.164: bytes=32 time=41ms TTL=55
Reply from 62.115.122.164: bytes=32 time=151ms TTL=55
Reply from 62.115.122.164: bytes=32 time=43ms TTL=55
Reply from 62.115.122.164: bytes=32 time=121ms TTL=55
Reply from 62.115.122.164: bytes=32 time=64ms TTL=55
Reply from 62.115.122.164: bytes=32 time=47ms TTL=55
Reply from 62.115.122.164: bytes=32 time=59ms TTL=55
Reply from 62.115.122.164: bytes=32 time=54ms TTL=55
Reply from 62.115.122.164: bytes=32 time=37ms TTL=55
Reply from 62.115.122.164: bytes=32 time=55ms TTL=55
Reply from 62.115.122.164: bytes=32 time=38ms TTL=55
Reply from 62.115.122.164: bytes=32 time=108ms TTL=55
Reply from 62.115.122.164: bytes=32 time=63ms TTL=55
Reply from 62.115.122.164: bytes=32 time=46ms TTL=55
Reply from 62.115.122.164: bytes=32 time=40ms TTL=55
Reply from 62.115.122.164: bytes=32 time=70ms TTL=55
Reply from 62.115.122.164: bytes=32 time=44ms TTL=55
Reply from 62.115.122.164: bytes=32 time=61ms TTL=55
Reply from 62.115.122.164: bytes=32 time=124ms TTL=55
Reply from 62.115.122.164: bytes=32 time=52ms TTL=55
Reply from 62.115.122.164: bytes=32 time=39ms TTL=55
Reply from 62.115.122.164: bytes=32 time=58ms TTL=55
Reply from 62.115.122.164: bytes=32 time=51ms TTL=55
Reply from 62.115.122.164: bytes=32 time=105ms TTL=55
Reply from 62.115.122.164: bytes=32 time=93ms TTL=55
Reply from 62.115.122.164: bytes=32 time=114ms TTL=55
Reply from 62.115.122.164: bytes=32 time=118ms TTL=55
Reply from 62.115.122.164: bytes=32 time=53ms TTL=55
Reply from 62.115.122.164: bytes=32 time=89ms TTL=55
Reply from 62.115.122.164: bytes=32 time=101ms TTL=55
Ping statistics for 62.115.122.164:
    Packets: Sent = 100, Received = 100, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 35ms, Maximum = 163ms, Average = 51ms
