One month of connection drops - still no fix... Who do I complain to?
- One month of connection drops - still no fix... Wh...
25-03-2020 10:43 PM
We have had on-going connection failures since Feb 23rd(!!!) - averaging around 5 drops per day mainly during working hours. Not the best situation when you're working remotely! On the worst days the connection has dropped TEN times!
When the router isn't reconnecting, the blue light on the front of the Plusnet Hub One contually flickers.
The first support ticket was actually closed by "support" immediately after the Openreach engineer visit had been booked booked - so no help there!
With the second support ticket, an Openreach engineer visited and actually replaced the whole master socket which produced -zero- improvement in the issue.
We have since replaced our telephone handsets with no impact
Plusnet Support are always really polite and keep testing the line before booking an openreach engineer to visit which results in me being told there's nothing else can be done.
Different people say different things - it's a broadband problem, no it's a line problem, no it's a broadband problem... The problem still hasn't been fixed.
What are the odds of the router being fault (about 2-3 yrs old)?
What are the odds of Plusnet sending me a replacement router to see if that corrects things? It's the only thing left that hasn't been either tested or replaced... (In the past I've even been asked "Do you have a spare router you can use?" Really??!!)
Can anyone tell me where the web page to raise a formal complaint is hidden?
I've been a loyal Plusnet customer for over 10 years and I'm now totally disillusioned with the level (lack) of customer service and support - I'm not getting anything remotely like the service I expect to receive for the money I pay.
I JUST WANT MY BROADBAND TO WORK LIKE IT DID AROUND THREE YEARS AGO WHEN I UPGRADED TO FTTC...
Re: One month of connection drops - still no fix... Who do I complain to?
26-03-2020 8:16 AM
26-03-2020 8:37 AM
Moderators Note
This topic has been moved from ADSL Broadband to Fibre
26-03-2020 9:00 AM
26-03-2020 9:07 AM
Probably because in your original post you stated that you connected to fttc 3 years ago
26-03-2020 9:14 AM
26-03-2020 9:16 AM
It's a link in the footer of every page "Complaints code of practice"
26-03-2020 9:22 AM
@Flatlands wrote:
I'll repost on ADSL thread as I'd like someone to reply and maybe help (or give me some advice) I'm getting desperate for some help or advice off Plusnet.
NO! This is the correct board for FTTC problems to be picked up quickest for Plusnet staff and Community members to respond.
26-03-2020 9:22 AM
My apologies, I didn't read carefully enough. I suggest that if your query is unrelated to @CaptainCorcoran 's you might get a better response if you started your own thread
03-04-2020 9:20 AM
Hi @CaptainCorcoran,
I'm very sorry for the inconvenience that this fault has caused you and for the delay in picking up your post on here. Having checked your account, I can see that you have since discussed this with our faults team and a new router has been sent for you to try. Have you received the new router and, if so, has this made a difference to your connection?
03-04-2020 11:04 PM
New router has had no effect - even when connecting router and phone via microfilter in test socket!
This is now being returned and yet another Openreach engineer visit has been arranged - 4 so far if I remember correctly!
At my end I've done everything asked of me and more - disconnecting everything, reconnecting everything, using wifi only, moving other equipment away from router, even buying new phone handsets and ethernet cables. It seems clear now that it's not my equipment or my original Plusnet router at fault so it must be the physical line coming into the master Socket - which Openreach have actually replaced!! IMHO the next thing that needs to be done is for Openreach to admit theres a bad line and install a new line to my home.. I just want to be able to use my broadband (working from home) without having to suffer from an average of 5 drops per day for about the last 6 weeks
Totally exasperated by everyone's frequent excuses, evasions and general refusal to take responsibility for fixing this!
04-04-2020 2:09 PM
I'm sorry to hear that the issues are continuing to occur despite the new router having been installed. I have reviewed the open Faults Ticket on the account and raised a response, which can be viewed here.
07-04-2020 11:08 PM
Further to my on-going problem with frequent disconnnects (average 5 per day, up to 11 drops in a single day), I have noticed from the Event log that my Down Rate falls to as little as 18497Kbps and the Up Rate goes as low as 516kbps.
Surely this is below the minimum guranteed speed for FTTC broadband...?
Since Plusnet is a signatory to Ofcom's Voluntary Speed Code of Practice can I please have a definitive statement as to what my minimum guaranteed speed is? I can't find it anywhere on your website but it must be displayed -somewhere- (but obviously not anywhere that's easy-to-find)...
18-04-2020 2:36 AM
