One Hub can’t connect, solid orange light
Gman101
Hi
I've tried to set up my new One router but despite the correct broadband account details being entered, router reset, account reset and passwords reset, and hardware fully set up, I'm still having difficulties getting rid of a solid orange bar and orange broadband symbol on the router. The original 'setup' dsl username appears to connect but no Internet connectivity is obtained. Any ideas as to how to rectify this?
Many thanks in advance
7 REPLIES 7
Gel
Aspiring Champion
Fixes: 29
Re: One Hub can’t connect, solid orange light
Gman101
Thanks Gel for the quick reply.
Indeed, I've had the confirmation email on 6-11-18 to say it's up and running, if that helps
Gel
Aspiring Champion
Fixes: 29
You may need to reset router via use of paperclip being held in reset hole on router.
Hold in for 5 seconds, then see if that sorts, when it reboots; if not go into admin page of router
using username & p/word shown on tab on back of router. Double check user name & log in/ p'word
are correct.
Gman101
Thanks again
Just reset the router, but to no avail, despite changing the bb username and password to mine from setup@plusdsl.net?
MasterOfReality
Fixes: 57
Hi @Gman101
I can see that your router has established a connection to the internet.
Can you confirm if you are able to use the service now?
Thanks,
MoR
Gman101
Hi MoR
Indeed it's all connected and working a treat. Thanks for clarifying that and your help!
G
JOLO
Fixes: 77
@Gman101,
That's good to hear. Please let us know if you have any further issues.
